No start issue, battery corrosion?
Old Sep 10, 2014 | 08:19 PM
98MaximaDriver's Avatar
One of the max's wont start. Its my relatives DD. They took it to the park down the street and it wouldn't start on the way back. Its a 98 auto.
I went down there and found a big mound of blue crap on the positive battery and even ater scrubbing it off the car wont start. At first the key fob wasn't working to open the doors and what not but after cleaning the blue crap off it the key fob started to work but no start.
Then i tried to jump it and no go.. So i ended up pushing it home.
At that point i grabbed baking soda and water and went to town on the positive terminal with a hard brush. After it was good to go i checked with a volt meter and i was getting almost 12 .. it was like 11.89v.
Not sure whats going on. Starter never showed any signs of going south! Can anyone clue me in .. i checked fuses and looked around and didn't find nothing out of place.
Usually when the starter starts to go it starts whining or something. Im getting no sound when turning the key to start the car. No click no nothing just crickets.
I do hear a barely audible sound coming from the engine bay when i put the key in the on position. But when i try to start i get nothing.
Old Sep 10, 2014 | 08:25 PM
Might be a bad ignition switch. Jiggle the key as you're trying to start it and see if that does the trick.
Starter could be locking up. Grab a long pole and smack it a few times. See if the car tries to crank.
Old Sep 11, 2014 | 10:17 AM
M in KC's Avatar
Your need more voltage to crank than 11.98ish. Try charging the battery up with a trickle charger. If the battery's condition can be improved, have someone hit the ignition switch while you read the voltage drop across the battery. You might have an alternator that has checked out on you. Did your relative mention any dash light on just previously to it not starting.? Just so we are clear this is a no start condition vs. a no crank condition. Many times folks mistaken use the two terms interchangeably when they are not.
Old Sep 11, 2014 | 10:23 AM
With 12 volts, it should at least attempt to crank. Plus, even though 14V is ideal, it should crank over with just 12 volts.
Sounds like a no start issue to me because he says "Im getting no sound when turning the key to start the car. No click no nothing just crickets." and "Then i tried to jump it and no go.."
Old Sep 11, 2014 | 11:03 AM
Also, although you cleaned the battery ground, all the main grounds should be removed/sanded/cleaned too.
Old Sep 11, 2014 | 01:59 PM
DBear's Avatar
And look carefully at the battery cables, to make sure there's no corrosion going up inside the insulation.
Old Sep 11, 2014 | 02:24 PM
Blassmasta's Avatar
Main Ground
What The Wizard said. Just went through this. Go after the main ground on the block. Do this first. Then move on to other stuff. I found out the hard way - with luck you won't have to. Jack it up, get under there and clean it up. 20 minute job.
By the way - my battery posts were nasty too. But that was not the problem.
Good luck!
Check it out- https://maxima.org/forums/4th-genera...w-battery.html
Old Sep 12, 2014 | 01:22 PM
Guys forgive me absense.. Ive had a rough few days! I appreciate everyones input alot!
That i didnt try! I did try my another key but no joy..
I havent tried smacking the starter or jiggling the key so i will try those and report back. I sanded the inside of the battery connector to make sure all the corrosion was off it.. I used the baking soda and water pretty good too. Ill have too look for the main grounds and see if can clean em up..
There was! I poured as much water and baking soda on it as i had.. but i could litterally see it inside the cabling. The amount of blue corrosion was unreal.. it was like the size of 2-3 golf ***** on top of the positive terminal! What in gods name makes this stuff grow?
I cleaned it off with a brush only to return a week later to find more stuff..
Thats when i grabbed the baking soda!
Good luck!
Ok ... ill make sure to check the grounds and report back.
Argh... tough week for the max's.. First this corrosion issue and then i just took out my front lip and scratched up my bumper on some driveway on my 5spd! I stopped drinking about 5 years ago but man do i feel like having a drink!
Old Sep 12, 2014 | 02:25 PM
M in KC's Avatar
Yeouch, focus young Jedi, focus ...
If the neg. cable is all corroded up you might be just as well off to replace that one. AIRC its a straight shot to the block. The Pos. cable might be a little more involved I just don't remember.
Old Sep 13, 2014 | 01:07 AM
Neg cable is ok... its the positive. Its as if the neg cable is immune cause it was clean..
Custom front lip cracks free of charge here.
https://www.google.com/maps/@37.9779...pCMbqvpzOg!2e0
tsi6001
Oct 3, 2022 10:23 PM
Cotozic
Jun 28, 2017 08:01 PM
Tha'-Max
Aug 30, 2015 01:14 AM
305head
Aug 26, 2015 09:03 PM
doobadoo
Aug 15, 2015 06:43 PM
