Faulty MAF Symptoms
Old 09-18-2014, 05:55 AM
jgcable's Avatar
Faulty MAF Symptoms
What are the symptoms of a faulty or intermittently faulty MAF?
jgcable is offline
Old 09-18-2014, 07:36 AM
maxfever1987's Avatar
Easiest way to see is if you can pass 2500 rpm, that's the rev limit with a faulty maf, if you go more than 2500 rpm your maf is fine, if not than that's is what needs to be changed
maxfever1987 is offline
Old 09-18-2014, 08:39 AM
max-nutcase's Avatar
yes, but if its goin in and out you will have to do this when it is acting up...i seen over the yrs ,mafs will slowly start to go, and work fine sometimes and others not...
.good luck
max-nutcase is offline
Old 09-18-2014, 08:48 AM
M in KC's Avatar
Intermittent, drive-ability issues typically at lower/slower speeds, stalling when leaving from a stop at least that's what I recall mine doing.
M in KC is offline
Old 09-18-2014, 01:51 PM
njmaxseltd's Avatar
You really should keep this in the same thread, you've already got a lot of support there.
https://maxima.org/forums/4th-genera...oke-issue.html
njmaxseltd is offline
Old 09-18-2014, 02:06 PM
^Agreed. No need for side threads.
The Wizard is offline
TallTom
50
07-08-2022 09:54 AM
-ReLLiK-
04-29-2016 06:25 PM
Derrick2k2SE
11-19-2015 10:14 PM
zmcneely13
09-26-2015 02:26 PM
ballerchris510
09-10-2015 09:35 PM
Quick Reply: Faulty MAF Symptoms
