To those with cut shifter....>>>
Old Jan 22, 2002 | 09:37 PM
190hpKiLLA's Avatar
Granny Driven
I cut my shifter today about two inches and put aftermarket handle which makes it even shorter. It took mad long to do it. Is it bad to cut it like that cause the shifter was moving all over? I was holding it with my hand in N and then in 4th gear. I hope there is nothing to break. I respect your work cause I was breaking sweat after it. At least my shifter feels closer to 02 maxima nice and stiff.
Old Jan 22, 2002 | 09:44 PM
justmax's Avatar
Re: To those with cut shifter....>>>
Can you shift?
Hear any grinding or other noises?
Old Jan 22, 2002 | 09:47 PM
BillN
I know the feeling, Jeff K, one of his friends and I started with a dremel but that wasn't going to work so we went with elbow grease Anyway, you should be cool. I love the feeling of the shortened shifter too.
Old Jan 22, 2002 | 09:51 PM
190hpKiLLA's Avatar
Granny Driven
Re: Re: To those with cut shifter....>>>
Originally posted by justmax
Can you shift?
Its fine. It was a bit harder to switch but thats because I was cutting it for like 2h ours and couldnt lift my arm. I shift like a bat into 3rd now and I saved like 100 bucks.
Old Jan 22, 2002 | 10:36 PM
95emeraldgxe's Avatar
hrmm.......what about that leather/leatherette housing the shifter comes with.....how did u deal with that? - cut it?
Old Jan 23, 2002 | 12:43 AM
justmax's Avatar
The cut is way above the shift boot. I think the shaft sticks up like 3 or 4 inches above the boot if you just push it down a little.
Old Jan 23, 2002 | 04:04 AM
KWheelzSB's Avatar
How did you secure the ****?
Just curious - how did you go about threading the shift **** onto the freshly cut shift-shaft? Did you make new threads on the shortened shaft w/ a tap & die kit?
Thanks.
Old Jan 23, 2002 | 06:02 AM
Axra's Avatar
You just buy an aftermarket **** that uses set screws to secure it to the shifter. just wrap the shifter with some tape before putting the **** on to keep it from moving too much.
Old Jan 23, 2002 | 08:40 AM
geomax's Avatar
u actually did what i told u to do i fee l special
Old Jan 23, 2002 | 09:44 AM
SuDZ's Avatar
You use the stock ****? Or go aftermarket?
SuDZ
Old Jan 23, 2002 | 10:08 AM
guitaraus's Avatar
Old Jan 23, 2002 | 10:22 AM
MaximaRider's Avatar
when i cut my shifter on my 95 SE i used lock cutters it ate through the metal in a heartbeat, i was sick of elbow grease cause it wasn't working at all. I don't wanna cut the shifter on my 97 for the sole reason that i will be getting an STS. Remember cutting the shifter may make it look shorter but still throws like a 5spd truck.
Old Jan 23, 2002 | 05:13 PM
190hpKiLLA's Avatar
Granny Driven
Originally posted by guitaraus
Thank you for making it clear. I still dont get how the STS works(I thought it was just shorter). I feel the difference going into 3rd.
James92SE
142
Jan 2, 2024 09:23 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
Taino14
Sep 24, 2015 02:51 PM
