power antenna question
Old Sep 29, 2014 | 06:16 AM
jgcable's Avatar
My power antenna no longer works. When the radio is turned on I can hear the motor from the antenna working and when I shut the car off I can hear the motor working but the antenna no longer goes up or down. I tried greasing it but its shot. Is there any way to disconnect it so that its no longer activated when the radio turns on and off? Its in the up position now which is perfect.
Old Sep 29, 2014 | 06:23 AM
M in KC's Avatar
The signal wire to the motor is part of the pin out on the head unit. You would probably be better off cutting the wire at the motor if you didn't want the motor to run anymore. But consider this. The next automatic carwash you go through your antenna will get destroyed if left in the position.
My advise is to replace the mast assembly. Its pretty easy to do. Most likely your plastic track has broken or is worn out and is not positively engaging with the drive gear.
Old Sep 29, 2014 | 07:16 AM
PH98I30's Avatar
This issue was just addressed last week. You can easily replace the mast for about $15. Look for the thread. It's an easy job. Takes about 10 minutes.
Old Sep 29, 2014 | 09:40 AM
sbcoachnick's Avatar
Just disconnect the power plug at the motor assembly until you can get it swapped out.
Old Sep 29, 2014 | 03:11 PM
asand1's Avatar
Just unplug it from inside the trunk.
https://maxima.org/forums/4th-genera...extending.html
Old Sep 29, 2014 | 10:25 PM
ThaMax's Avatar
Depends on if you drive in an area where the roads are salted and whatever other junk has got stuck in there.
For me, it was a day of saturating with WD-40 and PB Blaster, then pulling on the last metal mast piece (rest all popped out) using 9-inch long nose vice grips while having the antenna motor assembly secured in a bench vice.
Pretty sure some non-essential pieces of plastic were broken during my replacement, but it's still working beautifully till this day
The Frye
Sep 2, 2021 11:03 AM
Maximan190
Dec 16, 2015 06:01 AM
Violator
Sep 9, 2015 10:14 AM
AT978
Sep 6, 2015 10:31 PM
