Replacing the EVAP canister vent control valve
The check engine light is on in my 1996 Nissan Maxima GXE, and the code says P1447. I did some search on this forum and found two posts that report the same problem and possible fixes. And I also found a video on youtube https://www.youtube.com/watch?v=e3owzQ094Fk that shows how to install it, but I am not sure how easy it is to replace it. Before I buy the part, what should I check/locate the problems? Thanks
If that is your problem replacing the valve is pretty easy. I'd take yours off and try and clean it first. I had this code a couple of years back and the plunger inside was hung up. A little cleaning and some WD-40 and she has been good ever since.
When I tried to replace mine, one bolt was seized and the nut broke loose in the canister. Before buying a new valve try to remove yours. Also, use some oil and forceps/screwdriver to free yours up, there is a good YouTube of this.
Its located on the drivers side rear wheel well on the forward facing side of the wheel well near the bottom. There will be a plastic splash guard in front of it. When you locate it hit it with some panther **** as others have suggested before trying to service it.
