problem with front left knocking during right turns
Old Jan 23, 2002 | 02:20 AM
aalenr
I seem to be getting a slight tapping sound from the front left when turning right or changing lanes it seems to be worse when i travel slower which is hard to do in a maxima.
the car has 70000klm so is it the shocks or should i be looking at something else??
thanks in advance.
Old Jan 23, 2002 | 04:17 AM
KWheelzSB's Avatar
Re: problem with front left knocking during right turns
thanks in advance.
Inspect your CV boots for rips, tears, or leaks. It's possible you have a transaxle, or half-shaft problem - if the boots get compromised, the gear oil/grease tends to leak out over time & this can allow gritty contaminants to make their way inside the boot which can chew up the drive gears on the axles prematurely.
People normally report "clicking" or "knocking" noises at low speeds when turning sharply and eventually "grinding" noises when the wear gets really advanced, in the case of bad CV boots/half-shafts.
Also, check the following link (click on: "Suspension, Strut Bearing R&R") to see if the symptoms are similar to those described for the front strut-bearing failure:
http://www.motorvate.ca/
Do you find the noise occurs when turning sharply at low speed on a level surface, or only when you go over bumps? If over bumps only, then you need to look to the suspension for possible culprits.
Best of luck!
Old Jan 23, 2002 | 05:26 AM
Toffy's Avatar
Re: Re: problem with front left knocking during right turns
Best of luck!
Definitely sounds like a CV boot problem!
Old Jan 23, 2002 | 06:47 AM
breaux124's Avatar
Here's the test:
Got to an empty parking lot, and turn your wheel to the far right and slowly (around 5-10MPH) drive in circles. If you hear a constant clicking/knocking sound - "click, click, click, etc" then it's most likely the a CV problem
If you can hear it without moving, like turning your wheel back and forth in park then it's most likely the Strut Bearing
Old Jan 23, 2002 | 07:18 AM
sinewave's Avatar
Also check your wheel lug nuts. This happend to me a few months ago. I found out someone tried to jack my wheels. They loosened all of the nuts on one wheel except the locking lug.
Old Jan 23, 2002 | 08:09 AM
Eric L.'s Avatar
I think its beyond a cracked CV boot. The CV joint needs to be replaced. In such a case, it is more cost effective to buy the entire halfshaft than to try to replace jus the CV boot and joint.
Old Jan 23, 2002 | 09:27 AM
BlancMax's Avatar
Usually you don't hear it if the boot is busted, sounds like the CV joint is cracked.
Old Jan 23, 2002 | 01:29 PM
aalenr
Old Jan 23, 2002 | 05:51 PM
CHIGGARMAX's Avatar
Re: Re: Re: problem with front left knocking during right turns
I have the same problem. I took the car to the parking lot.
Drove in circles (counter clockwise) i can hear some metal grinding sound. Clockwise the sound was softer.
I check my rims and the inner wheel well and saw no oil stains.
4000 miles ago, I took it to Nissan dealer and complained about the nosie. the mechanic couldn't found anything except the right wheel was grinding to the protective plastic.
Should I worry??
What other procedures can I do??
CHIGGARMAX
95 GXE AUTO
STOCK 53K
alixc
Aug 11, 2020 01:48 PM
trasmadean
Feb 1, 2017 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
follyburr
Aug 7, 2015 09:50 PM
rhonster
Aug 6, 2015 05:46 PM
