Heater Core Replacement i need help
Old Oct 31, 2014 | 03:37 AM
tarikcoskun1's Avatar
İ have ordered aftermarket heater core from usa and i live in turkey and they are without inlet outlet pipes, i will go to repair center for changing that,what can i do for this situtaion ? can we use old ones it is possible ?
Old Oct 31, 2014 | 04:34 AM
CS_AR's Avatar
Can you post a picture or a link to the core you ordered?
Old Oct 31, 2014 | 04:37 AM
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
This is i have ordered
Old Oct 31, 2014 | 05:00 AM
CS_AR's Avatar
The ones I've seen have plastic pipes like the core in the picture below. Maybe you can move or get some plastic pipes for yours.
http://www.autopartswarehouse.com/sk...3-1600242.html
I've had more trouble with the plastic pipes crumbling on an old core than with the core leaking.
Old Oct 31, 2014 | 08:40 AM
i have the heater core i just need inlet and outlet pipes. i bought this,
http://www.amazon.com/gp/product/B00...iglink20459-20
what can i do now ? can i use old ones ?
Old Nov 1, 2014 | 03:43 PM
CRiME's Avatar
oem ftw!
Why did you buy that after it clearly states in the "bad" review, and also in the customer questions & answers, that it does not come with the pipes? As CS_AR said, the pipes are usually the weak point of the core. One of mine cracked, and I ended up replacing the entire unit. If you can manage to get your old ones off without breaking them, you may be able to re-use them. On the ebay site for the heater core that you ordered, it says "Requires the use of OEM pipes," so I guess that is what they expect you to do.
If your old ones are damaged, you may have to order a set from Nissan. Here is the part, courtesy nissan has them for $19 each, but I imagine the shipping may be expensive and may take some time to get to Turkey:
http://www.courtesyparts.com/27025m-...-p-131577.html
For reference, the OEM core at Courtesy is $219:
http://www.courtesyparts.com/27115-c...-p-189544.html
This diagram should help you double check everything that you need. Part # 27157 appears to be a washer which you may also need:
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
