yet another clutch bleed problem..
Old Nov 21, 2014 | 07:45 PM
maxFL0's Avatar
soo lately while driving my car, the clutch has had a spongy feeling to it and i would have pump my clutch to get the firm feeling to it.. until today.. when i finally said enoughs enough and decided to bleed the clutch n try to get the air out of it..
but FML..
i had my brother press down on the clutch and i attached a piece of clear tubing to the slave cylinder.. i then opened up the valve and NO FLUID WAS COMING OUT..then.. i went to the master cylinder drain valve n opened it up.. and ALSO NO FLUID WAS COMING OUT..
I then disconnected the steel line that connects to the master cylinder and i was assuming fluid was gonna start leaking out.. but again .. the reservoir stayed full..
im not a mechanic or anthing but im pretty sure i need a new master cylinder right? or no??
also.. should i change my clutch lines to just one stainless steel clutch line from the master cylinder to the slave?
thank you in advance..
Old Nov 23, 2014 | 06:38 AM
maxFL0's Avatar
any one know where to buy a stainless steal clutch line? anyone?
Old Nov 23, 2014 | 06:53 AM
CS_AR's Avatar
Last year I bought a NCCL-201 Techna-Fit Clutch Conversion Kit - Complete from Slave to Master Cylinder for 95-01 Nissan Maxima I bought it from http://www.jscspeed.com/
Let me see if I can find some pictures.
Are you replacing the clutch master cylinder at the same time?
Old Nov 23, 2014 | 10:53 PM
maxFL0's Avatar
I jus got done replacing the clutch master cylinder but nothing has changed.. the pedal sinks right to the floor and no pressure builds up..
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
carlosvq30
Sep 26, 2015 09:44 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
Maxxx10
Sep 13, 2015 03:16 PM
