Motor finally blew at 397k miles
Old Feb 4, 2015 | 08:23 PM
deezo's Avatar
I drove the hell out of this car for the 15 years I've owned it. At this point in time, it has been my DD day in and day out. I also would take it on road trips.
Recently the timing chain started rattling more and more so I knew something was going to happen. I was cruising at 70 mph from work tonight and I was listening to my headphones and the car jerked a couple times. I'm thinking, "WTF was that?" Turn off the music and I hear a loud tapping under the hood while I'm cruising. I pull off the highway to see what's going on and the car just shut down. I was about 20 miles from home so I said "F it. If I'm going to have to get this thing towed, then it's I'm going to get what's left of this engine. She got me 4 miles from home and it started rapping louder and I was losing power.Then, the chain broke and I saw smoke afterward. Wouldn't start back up after.
I solute this engine since it has done it's job and did it damn well without a problem for so many years. I'm going to drop another motor into it so I'll need some recommendations from some of you knowledgeable folks here. The tow truck driver told me to order an engine from Japan Direct but their page is having problems. After finding a motor, I'll need a good installer who's local to the Raleigh Durham area.
Old Feb 4, 2015 | 08:42 PM
asand1's Avatar
3.5 swap time!
Old Feb 4, 2015 | 09:44 PM
Jprocs24's Avatar
397K miles?! +1 on the 3.5 swap!
Old Feb 5, 2015 | 02:03 AM
97_GXE's Avatar
Was that the original timing chain?
Old Feb 5, 2015 | 02:09 AM
max ride 41's Avatar
good news for me!!! i only have 266,000 on mine so another 130,000 would be sweet!!! glad to hear your keeping her, new motor you say??? easy, 4-500 bux for a low mileage motor no problem.
Old Feb 5, 2015 | 04:23 AM
theWalkinator's Avatar
Damn! 397k, that engine served you well, +2 for 3.5 swap, there should be plenty 5th gen Max in your local junk yard or just move on to 2002 ~2003 Max. Mine is almost 200K and the engine is still going strong and it will outlast the body!
Old Feb 5, 2015 | 06:32 AM
deezo's Avatar
Yeah, everything inside the engine was original. IMO, it's still good to know the timing chain ended up being the problem and nothing inside the engine gave up.
I don't know if I want to do the 3.5 swap because I don't have the time and I don't want to have to piece everything together in order for things to work right.
Old Feb 5, 2015 | 06:48 AM
CS_AR's Avatar
I replaced the TC tensioner on my I30 at appx 225,000 miles when it first started to allow a morning click. It has 275,000 and going strong today.
Sent from my Z998 using Maxima
Old Feb 5, 2015 | 07:57 AM
maxprivate's Avatar
Black Lion
If you want simple then just throw another 3.0 in man. I had my 97 maxima 17 years had about 155,000 miles on my 3.0 never had issues until I installed the SCrg and got a lousy tune which blew my Pistons seals. Smh
I'm going with a 3.5 swap though cause I wanted more power for boost and found a 3.5 already on 3.0 timing for cheap. Good luck.
Old Feb 5, 2015 | 08:34 AM
uttadms31's Avatar
Congrats man on going that long. I'm at 236k still on original tranny hoping to get to 300k at least. How many trannys did you go through? Any original parts still in it like power steering pump, water pump, or fuel pump?
Old Feb 5, 2015 | 08:52 AM
Blood on Black's Avatar
If your looking for an experienced person to do swap for you in NC, this is who I would recommend: https://www.facebook.com/Max4DSC. Not sure if he is on the org. Idk how far Burlington is from you, but I would say it's worth the trip for quality. Also, he may be able to help you source the swap parts.
Old Feb 5, 2015 | 09:18 AM
Crusher103's Avatar
I can help you install. I think im the only person that is generally local. Its not hard i have a hoist and everything else. I honestly wouldn't bother looking outside of our local JY in NC unless you are looking for a motor to do a build on.
My suggestion would be go on Car-part, find a normal 02-08 VQ35 less 100k on it. Pathy TB drilled cams(NO ADAPTERS) and spacers and your set. Only other thing you will need to buy is a need an IACV adapter. Most of the parts you will need are timing related parts which is what broke on your old motor. In fact most of the parts you would need i have sitting here collecting dust.
The only thing i dont know is the auto trans, never had to work on a 4th gen auto
Old Feb 5, 2015 | 11:10 AM
dwapenyi's Avatar
If you changed the tensioners before all the mayhem do you think the car would have kept going, or was the chain just done?
Old Feb 5, 2015 | 12:14 PM
2kMaxim's Avatar
Yeah Im curious too as I have 203k on my de-k.
Isnt it like an 800$ job for a new chain and tensioners?
Old Feb 5, 2015 | 02:47 PM
deezo's Avatar
Most def. I just didn't want to put any more money into this engine. I knew I was going to have to swap a ton of parts due to the age of the vehicle.
Old Feb 5, 2015 | 02:53 PM
deezo's Avatar
Let's meet up and talk about this then and figure out what's reasonable for you to help me get this done. I'd rather have one of the members here help me out than a shop. I had issues with an engine shop in the past and wanted to beat the dude's **** for lying about doing work he hadn't even started to do on my truck.
TBH, I'd love to have a 3.5 put in this thing because I like the way it would drive with my suspension setup. I just have a lot going on where I can't do a huge job like this now. I'd like to get this car back on the road in the next couple months.
Old Feb 5, 2015 | 02:54 PM
deezo's Avatar
Content not found but thanks anyway.
Old Feb 5, 2015 | 02:55 PM
deezo's Avatar
I had the tranny rebuilt at 305k. I was still on the same water, fuel and steering pump. I think I'll be replacing the fuel pump though so I don't end up stuck again.
Old Feb 5, 2015 | 02:56 PM
deezo's Avatar
Yes.
Old Feb 5, 2015 | 02:57 PM
deezo's Avatar
thanks. The more you guys keep talking about the 3.5, the better it's looking to me. I will make sure it doesn't come out of a 6th gen though.
Old Feb 5, 2015 | 03:31 PM
george__'s Avatar
I thought it was the gen 5 engines (02-03) that were considered bad due to oil burning issues???
Old Feb 5, 2015 | 05:05 PM
deezo's Avatar
Originally Posted by george__
[/B]
I don't know about that but my brother's 6th Gen was a POS. Thing was burning oil and having all sorts of issues.
Old Feb 5, 2015 | 06:19 PM
maxprivate's Avatar
Black Lion
[/B]
02-05 if I'm not mistaken have issues with leaking valve covers. My engine is from an 06 Maxima and I got brand new valve covers just to be safe.
Old Feb 5, 2015 | 06:51 PM
TurboA32's Avatar
All 3.5's burn oil
Old Feb 5, 2015 | 09:52 PM
asand1's Avatar
Originally Posted by TurboA32
All 3.5's burn oil
That is an idiotic statement.
Sent from my XT1060 using Maxima
Old Feb 5, 2015 | 10:30 PM
Cotozic's Avatar
Yup.
I've got no leaks and no burning. 128k+
I like the 3.5. It's not definite that the motor will burn oil, and I don't think it's usually too big of a deal for those who do have some burning. Not like you ever see people swapping down to the 3.0
Old Feb 5, 2015 | 11:39 PM
well, to be fair here all 3.0's have the timing chain issue, ( at least in my experience ) at a certain mileage due to plastic guides. my max has had a "rattle" since i bought her almost 10 years ago with 129,000 on her and now at 266,000 it rattles especially louder in the colder, but also warmer weather. after she warms up she usually quiets down and runs right.
Old Feb 6, 2015 | 12:15 AM
TurboA32's Avatar
No it's not an "idiotic" statement even the new vq's burn oil
http://www.the370z.com/engine-drivet...nsumption.html
Old Feb 6, 2015 | 12:20 AM
TurboA32's Avatar
Originally Posted by Cotozic
Yup.
For your sake keep doing what your doing
Old Feb 6, 2015 | 12:28 AM
Les7311's Avatar
Scribed...
Old Feb 6, 2015 | 03:14 AM
asand1's Avatar
I am at 308,000 miles with no timing chain noise.
While all 3.5s might have potential to burn oil, you cannot say that EVERY 3.5 ever built burns oil.
Speaking in absolutes is not a good idea.
Old Feb 6, 2015 | 06:49 AM
q.man06's Avatar
If you're going to go vq35, get one from an 08+ altima or 09+ Maxima. So much to be said about the late vq35's and it wouldn't be much more work to get running in your car over an 02-07 vq35.
Congrats on getting that many miles though, too often I see cars in the junkyard with <150k
Old Feb 6, 2015 | 06:58 AM
2kMaxim's Avatar
No timing chain issues here over 200k
Old Feb 6, 2015 | 08:03 AM
Bonka's Avatar
Schnell kaputt
How's the condition of the body?
Given your use I would just throw in another DE and call it a day (maybe DE-K/MEVI). The original engine brought you to this mileage and I can't imagine much more power for this chassis. A decked out 4G still handles just a little worse than a shopping cart with one bad wheel.
You have the G8 anyway
Old Feb 6, 2015 | 08:19 AM
deezo's Avatar
The body is in damn good condition withno major accidents. I've taken care of this car but I do need new seats though.
H&Rs and Illuminas are still good. I love the way this car drives with my suspension setup and the 3.5 would definitely enhance everything else I still like about driving this car.
Very true, she's a beast but I don't want to drive it everyday. This is my chillout ride.
Old Feb 6, 2015 | 09:55 AM
Crusher103's Avatar
All 3.5's burn oil
wAt?
This. To all of those post.
1st. The excessive oil consumption has been tracked back down to the Cats and precats breaking up and being sucked back into the combustion chamber and damaging the rings. A compression check and leak down test will determine if you have a ring problem.
2nd. Most of the 370s issues are being caused by improper break in. But the same cheap cat issue that has plagued nissans since the 5th gen persists. There are plenty of VQ35 on this site that do not burn excessive oil. I know quite a few Z/G owners, no oil consumption issues.
3rd. You do realize how many VQ35 are on the road right now right? ALL OF THEM burning oil? Not one slipped through the oil burning net? Because i dunno i seem to have a VQ35 that doesn't burn oil, i know at least 10 people with non oil burning 3.5s....This is the same argument people say about mitsu 4g63 and crank walk, 2% of all motors are effected but people blow it WAY out of proportion.
Now unless you meant all engines period burn a little bit of oil because thats just normal operation then i retract my statement, 1/2qt with in oil change intervals is acceptable and perfectly normal in any car.
No.
I have one in my 4th gen and it is a little more complicated then the simple 1st gen VQ35. He would have to work out how he is going to get his cams to work, its much different from the original 3.5 swap, and the throttle body in itself is a nightmare of customization.
The reason i said 1st gen VQ35 is because, his car is a daily driver. He can get a more reliable motor with less miles for not a lot more money and keep everything he is used too.
Old Feb 6, 2015 | 10:20 AM
cashoit's Avatar
when i had my 3rd gen max, the same thing happened to my timing chain. The rattle was so loud, it sounded like a helicopter lol.
Sorry about the car deezo. The easiest thing to do is to swap in another 3.0. But u already know that so no need to beat a dead horse.
And not every 3.5 VQ burns oil.
Old Feb 6, 2015 | 04:02 PM
TurboA32's Avatar
If I were you and plan on putting a 3.5 in your car and don't plan on removing it for as long as you have the car I would rebuild it with ARP rod bolts, ACL bearing, HR headgasket, HR headbolts, REV-UP oil pump, new main tensioner/guide, Nippon piston rings and new water pump seals and valve stem seals. There's obviously some people who like the 3.5 but you can't ignore the obvious issues it has just my .02
Old Feb 6, 2015 | 04:59 PM
george__'s Avatar
jeebus making a sports mobile
Old Feb 6, 2015 | 05:21 PM
TurboA32's Avatar
No just using better quality parts..........
