advice on coil packs
Old Feb 11, 2015 | 08:07 AM
7kingz's Avatar
can someone please post a link for coil packs adviced to use?
and types of spark plugs..
been looking around but cant find a recent link.
thanks
1999 maxima gle
Old Feb 11, 2015 | 08:49 AM
DennisMik's Avatar
For spark plugs, use what Nissan installed originally - NGK PFR5G-11.
DO NOT get e-bay coils, they fail in 6 to 12 months. Auto parts store coils have a spotty record, one time they are good, another time they are like e-bay coils. It is highly recommended that you use the Nissan ignition coils. If you order them from an on-line place like nissanpartszone.com or courtesyparts.com, it is usually less expensive than your local dealer.
An exception to this is rockauto.com. They sell the Hitachi brand which is the brand Nissan installed in the car.
In case you don't know, you need 2 different coils. The ones by the firewall (called the right side of the engine) are different from the ones by the radiator (called the left side of the engine).
Old Feb 11, 2015 | 09:05 AM
Maxima 97 SE's Avatar
If u can find the Mitsubishi coil packs for the maxima that would be great as those were the best coils for our cars. At the time hanshin coils would fail but these would lastvfor a very long time as they were a better quality product.
Old Feb 11, 2015 | 09:17 AM
7kingz's Avatar
http://www.am-autoparts.com/1999/Nis...20/359845.html
What u guys think about this?
Old Feb 11, 2015 | 09:23 AM
CS_AR's Avatar
Made in China? I would proceed with caution. If not OEM then Hitachi would be my only consideration. Are your coils failing right now?
Sent from my Z998 using Maxima
Old Feb 11, 2015 | 09:30 AM
DennisMik's Avatar
Those am auto parts coils are like the e-baycoils. Made in China, made to be replaced in 6 to 12 months.
Old Feb 11, 2015 | 09:37 AM
Turbobink's Avatar
+1 ... what's your issue.?
A resistance test on your coil packs will give an idea of their health.
If the resistance tests out OK, then perhaps have a look at cleaning the coil contacts and boot spring ends.
If you're still having issues and you're certain it's the coils, perhaps replacing just the boots (+ springs) would be a better alternative to replacing the entire coil assembly.
Old Feb 11, 2015 | 10:12 AM
7kingz's Avatar
P0141
p1320
p0300
Codes coming up from autozone.check engine light
Old Feb 11, 2015 | 11:41 AM
Turbobink's Avatar
Originally Posted by 7kingz
P0141
p1320
p0300
P0141
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
P1320
- Faulty power transistor unit built into ignition coil
- Ignition primary circuit is open or shorted (circuit to ignition coils)
- Ignition primary circuit poor electrical connection (circuit to ignition coils)
- Faulty ignition system condenser
- Crankshaft position sensor circuit
P0300
- Faulty spark plug (s)
- Faulty ignition coil (s)
- Clogged or faulty fuel injector (s)
- Intake air leak
- Fuel injectors harness is open or shorted
- Fuel Injectors circuit poor electrical connection
- Ignition coils harness is open or shorted
- Ignition coils circuit poor electrical connection
- Insufficient cylinders compression
- Incorrect fuel pressure
Of these possible issues what have you ruled out?
Old Feb 11, 2015 | 01:10 PM
7kingz's Avatar
Did 2 sensors.1 front 1 back.
the cat,conver.is dead.
was trying to kill a few codes
by changing all sparks and coil packs
Old Feb 11, 2015 | 01:19 PM
7kingz's Avatar
Wow...im looking @ buying a new max..with that List.
8 know their isn't a quick fix..being charged 100 an hr..4 work...was hoping coil packs and sparks..would @ least
help out 1 code...and the cat.conver..is dead..that's $200+
Muffler extra $100..not going cheap
but trying to save a dollar
Old Feb 11, 2015 | 01:25 PM
CS_AR's Avatar
Where are you located and how many miles are on the car?
Old Feb 11, 2015 | 01:28 PM
tosheto's Avatar
I have some coils laying around I would be willing to sell if you want OEM coils. PM me if interested.
Old Feb 11, 2015 | 03:53 PM
asand1's Avatar
What are your symptoms? Can you feel a regular miss?
Sent from my XT1060 using Maxima
Old Feb 11, 2015 | 05:17 PM
7kingz's Avatar
165,000
im in ga
Old Feb 12, 2015 | 04:53 AM
Turbobink's Avatar
Stop talking about replacing your coils until you've tested them and found that you've got failed units.
Have you tested any of the coil packs yet?
Old Feb 12, 2015 | 01:03 PM
CMax03's Avatar
STAY AWAY FROM Sorry AZZ Autozone....rockauto.com is a good source!
Old Feb 14, 2015 | 08:48 AM
7kingz's Avatar
packs are bad..went to shop
missfireing bad
i have low acceleration
Old Feb 14, 2015 | 08:56 AM
CS_AR's Avatar
missfireing bad
On your coil packs, do you see a name or emblem to identify a manufacturer?
If someone replaced ALL of the OEM packs with some aftermarket brand made in China, it could be the reason for a number of failing packs at the same time.
Old Feb 14, 2015 | 05:28 PM
asand1's Avatar
Wrecking yard OEM would be better than after market. After market tend to run fine, but trigger a CEL, as the primary windings don't have the right number of turns, always show the wrong ohms.
Do a balance test, unplugging one coil at a time to see which ones make no difference. Then only replace the bad with OEM from a member or yard.
Mitsubishi first, then Hanshin.
Old Feb 14, 2015 | 05:42 PM
CS_AR's Avatar
+1 on that.. I keep a couple of spare used OEM coils that I picked up in a junk yard from a wrecked car to use as replacements.
Old Feb 15, 2015 | 01:07 AM
7kingz's Avatar
so the pack that makes no change in engine responce?
is bad?
Old Feb 15, 2015 | 01:18 AM
max ride 41's Avatar
yup, don't throw money at the car. you'll learn the expensive way that that's no way to remedy problems with an old car. i have my original coils with 266,000 miles on them, find another mechanic, sounds like this one is just looking to spend your money for you.
Old Feb 15, 2015 | 07:43 AM
jholley's Avatar
is bad?
+1
With the engine running pull the coilpack. Do them all separately. If the engine shows no difference in performance then that coilpack is gone.
As members have noted your cheapest and best chance option is to pull OEM coilpacks at the JY.
Old Feb 15, 2015 | 08:08 AM
theWalkinator's Avatar
Originally Posted by jholley
+1
Should that just be the opposite? No difference, coil is bad, difference, coil is good.
Old Feb 15, 2015 | 08:14 AM
jholley's Avatar
+1
gone = bad
Old Mar 3, 2015 | 06:41 AM
7kingz's Avatar
this is an update for my max.
almost everything is done fixed
but now i have a po141 code
working that angle now
thanks
Old Mar 3, 2015 | 08:08 AM
dwapenyi's Avatar
thanks
As someone pointed out before..........
P0141
This could simply be a bad connection. Try unplugging that sensor then plug it back in. Corrosion/rust on the connector could cause bad readings to the ECU. A simple re-connect would brush some of that corosion away.
Mahmuth
Aug 16, 2024 08:23 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
