Painted calipers
Old Jan 24, 2002 | 06:50 PM
magnum658's Avatar
Painted calipers
I wanted to paint my calipers. What should i use?
Old Jan 24, 2002 | 07:11 PM
ejj's Avatar
ejj
Re: Painted calipers
Paint.
I just used high temp engine primer, paint and clear coat that you can pick up at any auto store. Worked great.
Old Jan 24, 2002 | 07:17 PM
MAXEJA's Avatar
clean everything before very well, 1 coat high engine temp primer, 3 coats high temp engine paint, 2 coats high temp clear
Old Jan 24, 2002 | 10:56 PM
Nismo's Avatar
I used about 4 coats of 1400 or 1500 deg. engine enamel
Old Jan 24, 2002 | 11:48 PM
NYCe MaXiMa's Avatar
also
make sure u clean the calipers before spraying them.. get a nice wire brush or a dremmel tool with a wire brush piece and get all the dirt and rust off the caliper 1st. Then there is special paint for calipers sold.
Old Jan 25, 2002 | 04:32 AM
KWheelzSB's Avatar
Originally posted by NYCe MaXiMa
also
He should start with aerosol brake cleaner 1st, actually, & scrub the caliper quickly with either a nylon bristle brush or small wire brush while it's still wet (dries quickly).
If there's still crud on them after this, I might do a dry run w/ the Dremel, but not before I got most of the brakedust off with the brake-cleaning fluid.
Brake dust isn't something you want to go out of your way to agitate & get airborne when it's dry. It's kinda tuff on the lungs. . .
(Btw, I'm one of the strongest Dremel advocates you'll find!)
Old Jan 25, 2002 | 04:43 AM
KWheelzSB's Avatar
Where to get a better variety of paint choices?
I've been to all the auto parts places, chains, etc. All they seem to have in high-heat caliper paint or engine enamel are the garden variety blah, blah, blah GM/Ford paints, which would be fine if I was painting a Chevette or a Pinto, but I'm looking for something a little more interesting, personally.
Anyone know any good sources online or elsewhere to get a better variety of high-heat paints? Ideally, I'm looking for a metallic royal blue or something like that.
Any leads appreciated. . .
Old Jan 25, 2002 | 06:11 AM
AndyXXL's Avatar
FoliaTec caliper paint kit comes with paint, thinner and brake cleaner. Great quality paint.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
