96 maxima leaking coolant from behind the thermostat housing?
ok so i had a pretty bad leak i took a look seemed as if it was coming from the thermostat housing/gasket. so i ran down to napa grabbed a new thermostat housing and gasket. replaced them and i start her up add some fluid and nothing still leaking bad. i noticed that its coming from behind the thermostat where i cant see. my question is what is directly behind the damn thing?
no its from further up I just did the water pump and thermostat + gasket. the leak is coming from right behind the thermostat right after the gasket. my question is what is it that the thermostat bolts to? from there strangely I believe the leak is coming from.
https://maxima.org/forums/4th-genera...-assembly.html
You'll need to loosen the idler pulley nut first.
As noted on page LC-14 (engine lubrication & cooling systems) those nuts require only 6-8 ft-lbs. If you don't have the Factory Service Manuals (FSM) then click on the link under the post CS_AR made.
EDIT: Cover the alternator with a plastic bag to avoid coolant spilling on it.
Yea i had a better look its for sure coming from behind the thermostat. Its literally pouring out from behind there i think my cylinder head may be cracked. Don't know for sure i have to pull my ac+alternator to see where the leak is coming from.
MikesChevelle
Aug 6, 2015 11:36 AM
