How to adjust idle with a broken tach.
Old Apr 1, 2015 | 07:58 PM
Striker2237's Avatar
Just like the title says, I replaced a bunch of componetes and cleaned the TB and ICAV but now I need to know the procedure for adjusting the idle with a broken tach. Thanks
Old Apr 1, 2015 | 08:16 PM
chrome91's Avatar
OBDII scanner that can give you live data readings should show RPM
Old Apr 1, 2015 | 08:46 PM
I didn't bring mine, kinda stupid on my part but never the less I don't have one with me so I need another way
Old Apr 2, 2015 | 05:18 AM
njmaxseltd's Avatar
1) Fix Tach
2) Scanner
3) Oscylloscope on the injector pulse, read the time scale, do math.
4) Listen, when it sounds good, it's set.
Pick wisely.
Old Apr 2, 2015 | 05:46 AM
cardana24's Avatar
Blown
my timing gun/light has a rpm function, so if you have a timing light that can read rpm use that.
Old Apr 2, 2015 | 10:15 AM
Gah! You guys are making me feel so stupid for not bringing things like the scanner and the light! I guess I'll just go with setting it by ear for now.......what's the worst that can happen right?
Old Apr 2, 2015 | 12:17 PM
Ah screw it, I just went and bought the best code reader advance auto had. I guess I'll just add it to the travel box after I'm done using it for data readings....better than having to guess what RPM I'm setting things to.
Old Apr 3, 2015 | 03:11 PM
Adjustment was mostly successful, idle screw backed all the way out gave me around 620 rpm. Tad low but good enough for now.
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
salty318
Sep 29, 2015 01:21 PM
