car wont start after winter storage
Old Apr 10, 2015 | 07:47 PM
avin's Avatar
Ok so I've done some searching but I cant really find my exact problem so here it goes...
So I stored my car (1999 5 spd) in the winter in a barn, and I was going to do a swap so I started taking everything apart (wiring, exhaust, etc.).
One of my buddies was really messy with his car/garbage and it attracted raccoons into the shop, I lost it when I saw one on the roof of my car so I moved out. Now I'm in a storage unit trying to get my car to run with the current engine (it ran fine before I stored it), I wired up everything but when I went to start it, it did nothing. I put the car on a battery charger and tried again, but it wouldn't even crank. Then I thought I wired the starter backwards, so i changed the polarity, bad idea... I put it back to normal and then tried starting it again and noticed that the security light stayed on when I put in the key and the rpm went up to 2000. (The car wont crank still, how is it getting an rpm signal)?...
Did I just immobilize my car??
Old Apr 10, 2015 | 08:41 PM
nsnrider's Avatar
sounds like you need to reprogram your key.
Old Apr 10, 2015 | 08:46 PM
CS_AR's Avatar
Is the security light on solid red? Did you unsuccessfully attempt to start the car 3 to 5 times with the drivers door open?
Old Apr 11, 2015 | 09:14 AM
avin's Avatar
I had the door closed ...
It stays solid red after you turn the key to start ;(
Old Apr 11, 2015 | 09:28 AM
JoshG's Avatar
is it a 99? probably has security on preventing it from starting.
Old Apr 11, 2015 | 09:30 AM
avin's Avatar
Yeah it's a 99. & so maybe I immobilized it ;(???
Old Apr 11, 2015 | 09:32 AM
JoshG's Avatar
yeah, if its solid red on a 99, chances are its immobilized.. CS AR should be on his way onto this thread to tell you what to do, probably a tow to stealership... or manually reset
Old Apr 11, 2015 | 10:47 AM
CS_AR's Avatar
Check out this thread and see if the reset will work. I accidentally immobilized my 99 in 2014. I was able to reset it.
https://maxima.org/forums/infiniti-i...on-solved.html
Sometimes you can and sometimes you cant reset the immobilizer. Unfortunately if you can't reset it, it will take a locksmith with special software to reset the immobilizer or a tow to the dealer to use Nissan Consult to reset the NATS.
Do you have two keys? It is possible for the chip in the key to go bad that will result in immobilization if you strike out.
Take a look at Item #2 in this lessons learned thread.
https://maxima.org/forums/test-posts...-infiniti.html
Old Apr 11, 2015 | 12:27 PM
avin's Avatar
Could I just swap in a 95 ecu or??
Old Apr 11, 2015 | 01:26 PM
CS_AR's Avatar
I think there are some threads on how to change the pins to swap in a pre-99 model ECU. It is definitely not plug and play.
Lakersallday24
Jun 16, 2019 01:35 AM
MplsMadMan
Sep 4, 2015 02:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
