Spongy brakes
Old 04-12-2015, 01:24 PM
DBear's Avatar
Spongy brakes
At some point recently I've developed spongy brakes. (My wife has been driving the Max lately.) Every 6 or 8 times, the pedal will sink almost to the floor, then pumps back up. I haven't done anything on the brake system recently, and the pads are all fine. I regreased the slide pins (on the fronts, anyway) a week ago. I just bled all four wheels, and the problem is still there.
I don't see any leaks at the wheels. I haven't been losing fluid at all, and when I'm stopped with my foot on the brake the pedal stays firm, which has always been my test for a bad master cylinder. But I'm not sure what else it could be if it's not the master cylinder.
Any suggestions?
DBear is offline
Old 04-12-2015, 01:52 PM
chrome91's Avatar
either not completely bled or maybe bad master cylinder
chrome91 is offline
Old 04-12-2015, 02:04 PM
vqmaxman's Avatar
Check the master cylinder for leaks,than bleed the calipers I am sure they were not bleed right or bleed enough.the master cylinder brake hose are secure not broken or loose. The vacuum brake hose.
vqmaxman is offline
Old 04-12-2015, 03:43 PM
Finkle's Avatar
Master cylinder. If there is no leaks, there is no place for the fluid to go, but around the plunger in the master.
Finkle is offline
04-16-2020 05:15 AM
06-06-2017 02:01 PM
leatherneck
09-30-2015 09:16 PM
HerpDerp1919
09-29-2015 02:02 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: Spongy brakes
