97 Maxima Reverse lights switch
Old Apr 17, 2015 | 02:50 PM
maxima297's Avatar
I've recently discovered that my reverse lights don't work when I'm in reverse. The bulbs and wires seem to be good, and I was told there's a switch to activate the reverse lights. If this is the case, where would it be located? I have a 5 speed 4th gen, just got it 3 months ago and am still learning where everything is on this car.
Old Apr 17, 2015 | 04:35 PM
DennisMik's Avatar
The reverse switch is combined with the neutral position switch and is on the transmission.
See page 7 in the link below:
http://boredmder.com/FSMs/Nissan/Maxima/1997/MT.pdf
Interestingly enough,the the transmission section (the link above) says the reverse switch uses pins 2 & 4. The electrical wiring diagram say the reverse switch uses pins 1 & 3. Obviously one of them is wrong, so check both halves.
Old Apr 17, 2015 | 04:42 PM
maxima297's Avatar
Would that also be why my car only starts in neutral?
Old Apr 17, 2015 | 07:38 PM
DennisMik's Avatar
As far as I know, it should start in any gear. The switch on the clutch pedal is for that.
I think the neutral position part of the switch is for the cruise control.
Old Apr 18, 2015 | 03:05 PM
yellow_cake's Avatar
For '98 and earlier: pin 2 & 4 has continuity in reverse gear, pin 1 & 3 in neutral.
For '99 models: pin 1 & 3 has continuity in reverse gear, pin 2 & 4 in neutral.
I got this info from the Haynes manual, which I used when diagnosing the switch on my '99.
Old Apr 20, 2015 | 07:30 PM
vqmaxman's Avatar
Try to check the pnp switch could be.bad,than check for voltage in the pins and harness wires.
Old Apr 21, 2015 | 01:22 AM
asand1's Avatar
Fun fact. When I was rolling down hill hill in neutral and hit resume, the engine shot up to 7k. Neutral does not matter, the clutch pedal cancels it.
Old Apr 21, 2015 | 04:41 AM
DennisMik's Avatar
The clutch switch is in series with the brake pedal switch and when either of these switches operate, they "undo" the SET button.
In auto trans cars the park/neutral switch is used in place of the manual trans clutch switch.
So a manual trans car does not use the neutral switch and that allows the cruise control module to rev the engine in an effort to maintain speed while in neutral. I think this was a big oversight.
fastcarny
May 18, 2020 10:40 AM
spidgeon
Aug 18, 2015 05:46 AM
Derrick2k2SE
Aug 12, 2015 06:47 PM
kjm900r
Aug 5, 2015 07:14 AM
yat70458
Aug 3, 2015 01:16 PM
