Alternator Failure Qs ...
Old May 9, 2015 | 11:33 AM
Turbobink's Avatar
So, if my original alternator fails, resulting in the brake and battery idiot lights and I replace it with a defective Reman'ed unit, would I not be getting the brake and battery idiot lights again?
Old May 9, 2015 | 12:26 PM
Maxima 97 SE's Avatar
Here you go this is the best deal around for an original Nissan maxima oem genuine alternator from ebay for only 190.00 http://www.ebay.com/itm/1997-1999-Nissan-Maxima-Alternator-Generator-OEM-NEW-Genuine-2310M-0L706R-/321745076465?vxp=mtr
Old May 9, 2015 | 01:54 PM
Daniel VQ30life's Avatar
you should yes, but possibly not, happened to my buddies 3.5 altima, lights didn't come on the second time but it was a bad reman'd alt
I love my A32
Old May 9, 2015 | 02:13 PM
chrome91's Avatar
if you get a bad reman alt the ABS, brake, etc lights will remain on. if you get a good new or reman alt or put in a good used one, the lights should be out
Old May 10, 2015 | 05:48 AM
njmaxseltd's Avatar
Does a wood chuck chuck wood ?
Old May 10, 2015 | 06:25 AM
dwapenyi's Avatar
Alternators are one of those things where going OEM is
Aftermarket is very risky.
Old May 11, 2015 | 04:48 AM
Turbobink's Avatar
Yep ... seems to be the case.
I'm a dumb-a**
I did quite a bit of poking a podding over the past weekend.
The alternator is either producing no (as in zero) charge or the charge is not getting to the battery.
With the car running and with a load placed on the battery I'm at battery voltage at best with a slow trend towards the negative.
I also checked voltage drop on the (+) side and got 0.02v which, based on my understanding, is fully acceptable.
I also have continuity b/t the alternator charging post and the (+) battery terminal, which tells me there's no short in the charging cable.
I'm convinced it's either a piece of sh*t reman'd alternator (i.e. literally defective out of the box) or a failure in the ECU that won't trigger the alternator to charge ... I can't really think how ECU damage would have happened based on the condition of the car and the fact that even with all of the work I've done on it lately, I never messed with the starting/charging system at all.
I'll pull the alternator ... a-friggin-gain ... and see how it tests out.
I'm really really hoping that that's the issue.
Old May 11, 2015 | 05:08 AM
dwapenyi's Avatar
The ECU is not connected to the Alternator.....it just pumps out electricity all the time....stabilized by an internal regulator.
TallTom
57
Oct 14, 2025 05:16 PM
