Grinding
Old May 16, 2015 | 05:37 PM
Antant2485's Avatar
Grinding
I hear a grinding noise I think it's coming from the front, while it's on motion and ten times worse when I hit the brakes. Brakes are in good condition, I'm sure my rotors are bad but it's weird it happened after my car was sitting for about 2 weeks....also I think my brake system is bad because the last time a changed the brakes was a longgggggg time ago....any suggestions on grinding???
Old May 16, 2015 | 05:44 PM
chrome91's Avatar
rotors rusty? if the car sat for 2 weeks and it rained, they probably have rust on them. go on the highway and do a few solid brakes and the rust should wear off
Old May 16, 2015 | 06:33 PM
asand1's Avatar
Originally Posted by Antant2485
Brakes are in good condition, I'm sure my rotors are bad ....also I think my brake system is bad because the last time a changed the brakes was a longgggggg time ago.
That doesn't sound like good condition to me. Make up your mind and get them fixed. Sounds like metal on metal to me. You will probably need pads and rotors. Might just be a rock stuck in the caliper too. Are you knowledgeable enough to check yourself?
Old May 16, 2015 | 09:43 PM
JoshG's Avatar
change em before you cause an accident.
Old May 17, 2015 | 10:51 AM
Antant2485's Avatar
Yea as a matter of fact they are rusty I'll give that a shot thanks...yes I'm mechanical enough to check, there is no rock, I know because I was in the process of changing my brakes because I thought that's what the grinding was coming from, and that's when I also realized they were in good shape, which is also weird because it's been almost 2-21/2 years since they've been changed and I got cheap ones lol
Excalibur23
Oct 13, 2015 04:33 PM
carlosvq30
Sep 26, 2015 09:44 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
Sep 15, 2015 06:47 AM
