help with the relay rad fan 1
Old 05-24-2015, 06:08 AM
beboski's Avatar
I was just trying to clean my grounds and found the relay rad fan 1 with one wire broken can you guys tell me what that relay do? Thanx
beboski is offline
Old 05-24-2015, 09:50 AM
Fakie J Farkerton's Avatar
http://en.m.wikipedia.org/wiki/Relay
Fakie J Farkerton is offline
Old 05-24-2015, 03:04 PM
DennisMik's Avatar
Radiator Fan relay # 1 is what makes the 2 radiator fans run when the engine coolant temperature reaches 203º F (95º C). If there is a wire broken off of this relay, then this is not happening.
But the engine won't overheat because the radiator fans are 2 speed fans. So when the engine coolant temperature reaches 221ºF (105º C) while idling or 212º F (100º C) while driving, then the high speed portion for the fans start up to cool the engine.
But with summer coming, fix that wire.
DennisMik is offline
Old 06-10-2015, 10:38 AM
maxam's Avatar
I have may be the same problem or semeler .
I noteced that the fan is not working proberly .
I have opeend the rely rad fan 1 and pressed it : no fan works .
rely rad fan 2 : the left fan working only .
rely rad fan 3 : both fan works but not in high speed .
maxam is offline
Miket2006
03-01-2021 03:55 AM
captchaos
03-15-2016 12:18 PM
zmcneely13
09-26-2015 02:26 PM
RWCreative
09-21-2015 11:01 AM
Quick Reply: help with the relay rad fan 1
