98' maxima fuel pump relay?
Old Jun 1, 2015 | 05:35 AM
Jewing1978's Avatar
I have looked under the hood and the dash everywhere. Where is this relay? I need to swap it... before I drop and buy a new fuel pump... Pics would be appreciated.
Old Jun 1, 2015 | 06:05 AM
maxfever1987's Avatar
It's on the inside of the car right under the drivers side fuse box area, underneath you will see the kick panel, remove it, and you will see a silver plate with 2 10mm bolts, revoke them, slide it out and it's a blue relay sitting right there
Kick panels located right under hood release lever
Old Jun 1, 2015 | 06:11 AM
If you have abs, you will need to move the abs module forward first
Old Jun 1, 2015 | 09:45 AM
DennisMik's Avatar
Why do you think that you might need a fuel pump? I ask because 98% of fuel pumps that get replaced are good.
Old Jun 2, 2015 | 06:09 PM
CMax03's Avatar
Bypass the relay ...with a short piece of wire with male bldes on each end! The two terminals illustrated on the Green Relay should be connected and if your problem still exist....Sure it's not ignition related?
kjlouis
Nov 24, 2018 06:09 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
