EGR Tube clogged
Old Jun 14, 2015 | 02:34 PM
jmd61's Avatar
EGR Tube clogged
Getting ready to do both my 97 and 98 Maxima clogged EGR tubes. My only concern is, has anyone had issues with one of the top 2 or bottom 2 bolts breaking, and if so any solutions or suggestions. Thanks
Old Jun 14, 2015 | 02:56 PM
DennisMik's Avatar
I didn't have any problems on my 97. But maybe you could spray them with PB Blaster before you start and use a six point socket.
There are no guarantees that you will or will not have problems.
Old Jun 14, 2015 | 03:23 PM
Turbobink's Avatar
No issues here.
Old Jun 14, 2015 | 03:49 PM
Daniel VQ30life's Avatar
I haven't had to do mine yet, but a few of my local maxima buddies have, never heard of any bolts snapping
maxfever1987's Avatar
First time taking off the manifold?thers four 12mm bolts behind it not just 2, 2 more bolts are to the left of the egr tube
Old Jun 14, 2015 | 04:46 PM
maximaham's Avatar
mine wasnt a problem, thats one of the first things i did when i got my max.
Old Jun 15, 2015 | 05:06 AM
jmd61's Avatar
Maxforever - Not the manifold just the tube between EGR and intake, 2 bolts in top flange and 2 in bottom.
All you that have not had a problem with bolts snapping did you do any kind of special prep before wrenching down on these bolts? I have always used wd40, is the rust buster spray the same or any better?
Thanks again.
Old Jun 15, 2015 | 06:22 AM
jholley's Avatar
Thanks again.
PB Blaster is the best penetrant for removing rusted materials. Similar to other member's my EGR mounting nuts came off their studs easily and no spraying was needed. One of the lower mounting studs needs to be hacked for nut removal clearance. I used my dremel tool for cutting that stud. You'll need to remove the IACV to reach the EGR tube nuts. The IACV gasket can be re-used but the EGR tube gaskets will need replacement. This HowTo thread listed in the stickies gives all the details for removing the EGR tube
https://maxima.org/forums/4th-genera...g-dummies.html
jmlee44
Oct 2, 2022 02:13 PM
Sep 27, 2015 08:37 AM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 19, 2015 01:07 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
