Speedo doesn`t work
Old Jul 19, 2015 | 03:40 AM
aachmedo's Avatar
Speedo doesn`t work
My speedo shows 0mph. A while back it started waving from 0mph to about 20-25mph and a few days later died. Shows 0 since. I took out the cluster and checked the screws in the back and the wiring. All seems to be fine. the car doesn`t stall and shows the ghost KS on the CEL and thats all. It`s a manual 1998 I30. Should i go buy a speed sensor or try something else? Maybe there is some trick for the problem? Thanks for helping.
Old Jul 19, 2015 | 06:58 AM
Slamrod's Avatar
Sounds like the VSS is shot. If the rest of the cluster is working except for the speedo then id def investigate the vss first. Try checking the connection/prongs of the sensor first - give them a good cleaning and check for any looseness and see if that does the trick. If not then go ahead and cop a new sensor, id assume youll want to stick with OEM like pretty much all the other sensors in these cars.
dr3am
25
Oct 22, 2015 08:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
cstrasz
Aug 27, 2015 08:07 AM
Flores94
Aug 13, 2015 01:17 PM
kenc15
Aug 5, 2015 08:29 AM
