lower ball joint replacement
Old Aug 4, 2015 | 06:02 PM
classymax420's Avatar
Hey guys, just have a quick question, when replacing my lower ball joints, if I just undo the castle nut, will I have enough wiggle room to press out the old and press the new ? Or do I have to take the axle out of the hub and all that jazz ??
Old Aug 4, 2015 | 07:51 PM
jerrod99_se-l's Avatar
It would be much better if you just replace the whole lower control arm...it has ball joint and all bushings already installed...and pretty easy to do! Replace both lca's at the same time...then get an alignment...
Old Aug 4, 2015 | 07:53 PM
Add on...if u replace the lca's you don't need to pull the axle at all..itll just drop down
Old Aug 4, 2015 | 08:21 PM
Fakie J Farkerton's Avatar
Old Aug 5, 2015 | 09:21 AM
Damn I have the lower control arms . I just didn't kno of I could trust the brand, cuz I didn't kno about moog before I bought them.. but word. Thanks for the help! Lcas it is!
Old Aug 6, 2015 | 06:56 AM
M in KC's Avatar
Ahh, bolt on what you have, assuredly it's better than what's on there and roll the dice. Either way, you know what you are dealing with and if your unknown maker's parts start failing prematurely you know what you need.
Old Aug 6, 2015 | 06:35 PM
asand1's Avatar
Disconnect the swaybar endlink, remove the six control arm bolts, loosen the ball joint not with an open ended wrench if its not rusted on, and wail on it with a hammer. After it cracks loos from the knuckle, remove the nut and take it to the bench or shop floor. Remove the snap ring and beat the joint out with a hammer. flip the arm over and knock the new one in with a hammer and big socket. I used a 3lb shop hammer and a piece of rail road for an anvil.
CRizz
41
Jun 7, 2021 05:42 AM
maxocar
Aug 21, 2015 12:57 AM
jhontelj
Aug 17, 2015 04:07 AM
soon2ownmax
Aug 13, 2015 02:19 PM
Flores94
Aug 11, 2015 12:53 PM
