High RPMs in first gear
Old Sep 3, 2015 | 12:07 PM
dcardello's Avatar
Hey everyone,
I'm experiencing high RPMs in first gear (>5000 rpm) before it drops into second. Other gears switch smoothly when driving. Recently I "repaired" the MAF sensor by re-soldering the three electrical contacts inside the sensor - if I did this improperly could that cause this issue?
I checked the transmission fluid level and it looked good. O/D light blinks several times occasionally on starting - so my tranny is trying to tell me something.
Thanks!
Old Sep 3, 2015 | 12:38 PM
Maxima 97 SE's Avatar
Since your OD light blinks that means theres something worng with tranny and something could be wrong with your first gear. But i would try to change the tranny drop resistor which is a sensor for the transimission and control tranny fluid when it shift and if it goes bad it causes erratic and harsh shifts. Its right behind the mass air flow sensor. Here is a pic. change that and hopefully thats all that is wrong with tranny.
Old Sep 3, 2015 | 12:49 PM
dcardello's Avatar
Cool - thanks for the information. Where can I find one of these?
Old Sep 3, 2015 | 01:41 PM
You can get one from the junk yard like picknpull or one from the dealer for 61.00. Here the part number 31037-71L00. Here a website i use that has all the original nissan parts and they are selling it for $45.00 http://www.nissanpartsdeal.com/parts...agram=310_A001 scroll down and look for Resistor Assy-Auto Transmission - Part Code: 31037
Old Sep 3, 2015 | 02:04 PM
dcardello's Avatar
Awesome, thanks for that. Can I also ask if you think it is really dangerous to drive with the car in this condition? Should I take it easy on the old girl or just drive carefully until it is resolved?
Old Sep 3, 2015 | 05:44 PM
martyl45's Avatar
I tried it once, very hard on the trans. Short term wont hurt it as long as you arent pushing it too much.
Old Sep 3, 2015 | 05:51 PM
What it will hurt is the motor mounts as the hard shift will put a lot of stress on the engine mounts and maybe even the axles. If you keep driving like that your trans will go bad. A bad tps sensor shot my tranny on my Nissan Quest.
Old Sep 3, 2015 | 11:44 PM
dwapenyi's Avatar
your engine computer "talks" to the tranny computer. Before trying the other stuff, try disconnecting and re connecting the tranny computer harness. With these old cars, electrical connections get corroded / loose over time, and that could wreak havoc on the system. I'm not sure where the tranny computer is, it's either behind the plastic panel on the passenger seat. When sitting there, you would kick your right foot to the right to hit that panel. Or, the tranny computer is in the center console behind the radio.
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
slowlifer
Sep 8, 2015 05:53 AM
