Anyone know where I can find an ECU for a 3.5 manual??
Old Oct 6, 2015 | 02:40 PM
SSC's Avatar
SSC
Or can I use the ecu from my vq30 with a 3.5 swap on my 4th Gen. My timing jumped and bent the valves a little. As long as I'm putting a new engine in I'm thinking of doing another vq35 swap without megasquirt. I don't wanna have to swap all the nats crap with it. Thanks
Old Oct 6, 2015 | 05:26 PM
Daniel VQ30life's Avatar
Get a jy ecu
Old Oct 6, 2015 | 06:29 PM
SSC's Avatar
SSC
Originally Posted by Daniel VQ30life
Get a jy ecu
Where do I find that?
Old Oct 7, 2015 | 03:08 PM
JDezMax95's Avatar
At a junkyard? jy ecu=junkyard ecu, just in case you did not know.
Old Oct 7, 2015 | 05:26 PM
Are you a wizard?
Old Oct 7, 2015 | 07:32 PM
schmellyfart's Avatar
Do some research on a full ECU swap. You may be getting in over your head.
Old Oct 7, 2015 | 08:20 PM
SSC's Avatar
SSC
Yes ive swapped a 3.5 in a 4th gen before but I used megasquirt as a standalone... Custome wiring harness and everything else. 5spd ecus are incredibly hard to find where I live. This is why I asked if I can use my current ecu with the 3.5 engine as a second question.
Old Oct 8, 2015 | 05:29 AM
Crusher103's Avatar
Search the classifieds the pop up all the time. But why go from megasquirt to a stock ECU?
Old Oct 8, 2015 | 03:49 PM
Auto ecu can be used with nistune
Old Oct 9, 2015 | 05:03 AM
asand1's Avatar
It's all in the stickies man. Swap 3.0 sprockets and chains onto 3.5 and then run 3.0 ECU.
Old Oct 9, 2015 | 03:34 PM
Yes, the 3.0 ECU can be used. Have a look in the All Motor forum in the stickies. Most 3.5 swaps around here are done using the 3.0 ECU.
Old Oct 10, 2015 | 02:54 AM
ef9's Avatar
ef9
Junkyard:
www.car-part.com
Old Nov 1, 2015 | 06:11 AM
SSC's Avatar
SSC
Awesome. Thank you. This is what I wanted to know. And to answer a previous question... I want a stock ecu because I sold my max with a 3.5 swap and megasquirt. The 4th gen I have now is stock and the timing jumped and bent some valves. The car isn't running right anymore. So since I'm changing the engine I may as well swap it with something better.
Old Nov 1, 2015 | 06:21 AM
SSC's Avatar
SSC
I can't seem to find the all motor thread at the moment. If you know where I can read up on it could you please link me? Thanks
Old Nov 1, 2015 | 06:23 AM
asand1's Avatar
The 3.0 ecu has no control for the variable valve timing. It will not run a 3.5 in stock trim. You will need 3.0 timing components swapped on.
Old Nov 1, 2015 | 09:32 AM
Here: https://maxima.org/forums/all-motor-61/
Old Nov 8, 2015 | 10:35 AM
SSC's Avatar
SSC
Thanks guys. Much appreciated
my03maxima
Jul 28, 2024 07:40 AM
osisray
Dec 9, 2015 11:05 AM
fx4five
Oct 18, 2015 06:57 PM
maxima297
88
Oct 11, 2015 01:15 PM
