My cruise control,rear deforst,ower locks and ower windows went out
Old Dec 3, 2015 | 11:28 PM
Brion Griffth's Avatar
I was coming back home from Thanksgiving when my cruise control, power windows,powerlocks,and rear deforst doesnt work. I checked and replaced the fuse but it kees blowing out. Not sure what to do.Help
Old Dec 4, 2015 | 12:06 AM
JvG's Avatar
JvG
So you replaced the fuse. Did it blow right away?
If not, what is the last thing you turned on right before the fuse blew?.
Big clue if you blew a fuse a second time , doing the same thing.
Old Dec 4, 2015 | 12:56 AM
The fuse didn't blow right away. I rolled the windows up and down to see if that would fix it when I replaced the fuse. I noticed it had gone out again when I was driving the car a few minutes later. I tried to use the rear defroster when I noticed it had blow again.
The fuse blew the first time when I was driving on the highway. I hit a small bum and I noticed the cruise control had stopped working. Its the bottom fuse 7.5.
Old Dec 4, 2015 | 01:37 PM
DennisMik's Avatar
That 7.5 amp fuse is fuse # 12. It supplies power to the BCM (Body Control Module) which in turn allows the windows, door locks, etc (all those things you mentioned plus some more that you haven't realized yet).
It is possible that the BCM itself is bad, but as JvG said, put in a new fuse and operate the windows, locks, etc one at a time and see when the fuse blows. If the fuse only blows when one specific accessory is used, that accessory has a problem. If the fuse blows with multiple accessories, then the BCM is bad.
What year is your car? There are differences with each year.
Old Dec 4, 2015 | 06:03 PM
JvG's Avatar
JvG
Thanks, Dennis. I did not think of the bcm. I was having the o p
identify the specific action which causes the problem.
Old Dec 4, 2015 | 08:00 PM
DennisMik's Avatar
Originally Posted by JvG
Thanks, Dennis. I did not think of the bcm. I was having the o p identify the specific action which causes the problem.
I don't know if you have seen the page in the FSM that shows what fuse powers what. It is in the EL section, Power Supply Routing. In the case of the 1996 FSM, it is page EL-19.
The names associated with the fuse are cryptic, but you can usually figure out what it means (i.e., D/LOCK means door locks). But those names are used elsewhere, specifically it is the name of a schematic. Sometimes this name is also in the alphabetical index section, IDX.
Once you look at the electrical schematic, you will then see the fuse.
Old Dec 5, 2015 | 02:26 AM
Its a 1999 model GLE. I owned a GLX and just had to buy another one. I swear those car so very reliable.
Old Dec 5, 2015 | 02:28 AM
Thanks everyone for you help. I'll try and see what making it go out. I'll keep you posted
Old Dec 5, 2015 | 01:51 PM
JvG's Avatar
JvG
You mentioned that the fuse blew when you are using the rear window defoster.
Experement..... process of elimination. You are trying to figure out which portion of the circuit has a problem.
So don't use the cruise control or the windows.
You might want to buy several of the 7.5 amp fuses.
Turn the electric defroster on. You might want to do this more than once. If the fuse lives, you can eliminate the defroster and then play with rolling only one window down, one at a time.
If the fuse lives, try another window. Till you know all four windows don't trip the fuse. Then the cruise control.
Going over a bump is interesting. Sometimes a corroded contact have intermittent contact. The bump appears to be the variable.
Old Dec 5, 2015 | 10:03 PM
Junebug1701's Avatar
Wow, I hope you called 911 so an ambulance could take the little guy to the hospital!
Old Dec 6, 2015 | 09:34 AM
DennisMik's Avatar
so bad
Old Jan 5, 2016 | 10:25 PM
mr_maxima1's Avatar
This is a common problem in these 4th gen maximas it is the cruse control on switch on the dash is is shorted out ant causes all sorts of problems and will keep blowing the #12 fuse i believe cant quite rember it it was #12 but anyway it a simple fix the switch pulls out with a little pry from a scruedriver and un plug the clip ive seen in a few the wiers burnt up in this case your on your own i had to fuger out how to by pass the swich
Callmefrosty
Dec 8, 2015 07:24 AM
rhc43
Dec 3, 2015 01:42 PM
Andy29
Dec 3, 2015 12:35 PM
BryceJayhawk
Dec 3, 2015 10:45 AM
Anthony Carbone
Nov 30, 2015 01:19 PM
