Transmission shifts hard between 1st & 2nd
Old Feb 5, 2016 | 06:24 AM
islanddean's Avatar
The fluid level is accurate but the transmission will shift real hard between 1st & 2nd gear especially from a complete stop. All other gears shift smoothly and without issue. Hoping someone can give me some direction as to what is happening and if it can be fixed. Thanks in advance.
Old Feb 5, 2016 | 06:57 AM
jerrod99_se-l's Avatar
Could be the drop resistor mounted in the driver side shock tower...
Old Feb 5, 2016 | 08:01 AM
islanddean's Avatar
Can you tell me what the drop resistor assembly does? How does this effect the shifting of the transmission? what are the symptoms of a bad drop resistor?
Shin
Feb 4, 2016 05:34 PM
kevin_ohio
Feb 3, 2016 04:25 PM
bizzy9221
Feb 2, 2016 08:40 PM
iwa2008
Jan 20, 2016 01:52 PM
