voltage to EGRC solenoid, CAL maxima GXE 1996
Old Feb 25, 2016 | 12:37 PM
max1996's Avatar
the ECM does not cut the voltage to the EGRC solenoid between engine rpm 2000-4000 to allow vacuum from the throttle body to pass through the solenoid to allow the EGR to operate as it should. Exhaust temp sensor changed. Intake, throttle body, EGR tube all cleaned. MAF changed. ECM changed. Suspect coolant sensor sending bad signal to ECM. Need to fix for CAL smog. Ideas?
Old Feb 25, 2016 | 12:56 PM
Any check engine codes?
If so, have you consulted the FSM for guidance on how to troubleshoot this? (You can look things up by code)
If you don't have the FSM, click the link in my signature for a free download.
Old Feb 26, 2016 | 07:01 AM
max1996's Avatar
Thanks but I've been using the FSM for years, thanks to Maxima.org. I use a scan tool that reads and shows all measured parameters. No codes just the EGR will not complete its test but functions properly during the solenoid bypass test. I believe the ECM is receiving a bad signal from some sensor and does not "cut" the voltage to the EGRC solenoid between 2000-4000 rpm. All components passed separate tests per the FSM.
Maximusdriver
Jul 9, 2016 04:16 PM
Jamielynn17
Feb 12, 2016 08:47 AM
Shin
Feb 4, 2016 05:34 PM
Sinscythe07
Feb 3, 2016 10:57 AM
Maxima 97 SE
Jan 27, 2016 09:38 AM
