hard driving in max
Old Jan 29, 2002 | 01:05 AM
jay_johnson's Avatar
hard driving in max
I just sent my maxima to the shop to get new struts. I overheard a conversation between my father and my mechanic in which my mechanic said that i have messed up my car from driving to hard. He said that I need a new transmission and a few other things. I don't drive that hard... i don't think. Has anyone else had to have repairs done because of your driving habits? If so, what have you had to have done. My car feels fine to me on the road. The tranny feels strong, ride is fine... a little rough, but that's what the new struts are for, and I don't hear any strange noises. Am I about to become victim to a bad mechanic? Please help me!
Old Jan 29, 2002 | 04:36 AM
98BlaximaSE's Avatar
Just go get a second opinion from another mechanic. Also how old is your car? Did you get it used?
Old Jan 29, 2002 | 06:06 AM
njmaxseltd's Avatar
I'd love to know how a mechanic "LOOKS" at your car and decides you need a new transmission? I wouldn't even let that guy change my oil after hearing a comment like that.
deezo's Avatar
Re: hard driving in max
All you should need from hard driving is pads and rotors. If you run your car into crubs then you'll need new struts. If your car is not bouncing all over the place, you don't need struts. If the tranny is shifting smoothly, you don't need a new transmission. Tell your father not to listen to the mechanic.
Old Jan 29, 2002 | 06:12 AM
pblaze's Avatar
Sounds to me like you're being set up for a scam. In the first place, when struts fail they usually blow a seal and leak fluid. The result is a soft and bouncy ride, not a harsh one. Struts CAN sieze, but the ride would rattle your teeth, and there would be no mistaking the problem. With a 7 year old car though, it may not be a bad idea to have a new set put on anyway. Alldata.com says that OEM struts are $90 each. Standard labor for the job is 3 hours to do both sides and an alignment.
Now for the big $$. Ask for a clear answer as to why you need a tranny. If you have an auto, it should: shift into and out of gear without delay, shift smoothly when accelarating, never "pop" out of gear, and not make any whining noises. Also, the transmission fluid should not look or smell burned. If any of this has happened you'll need to dig deeper. If none are happening, then you need some answers. Look at it this way, if the guy says it needs a tranny, but if the cars goes fine now, what will it hurt to drive the car until it really shows symptoms?
If you have a bad standard trans, the signs won't be subtle. Got fewer than 5 speeds? Do the gears ever grind while shifting? (bad driving aside) No? Then you can be pretty sure that nothing is broken and the syncros aren't worn out. Again, if the car goes fine, why do the swap now. In either case, I'm not recommending that you drive your car into the ground. Just be aware that major transmission problems will show symptoms that you will notice.
What's the worst that could happen? The guy could charge you $1500+, take a good transmission from you and throw a piece of junk into your car. Get a second opinion. I hope this helped. Good luck.
Old Jan 29, 2002 | 06:37 AM
iwannabmw's Avatar
Hard driving?? Sounds like he's scamming you. My car is track driven (road courses), autocrossed and driven hard daily. The only things I've done to my car are religious preventative maintainance and replaced wear items as I chew through them. You really have to abuse these cars for them to give you major problems. You definitly need a second opinion.
Old Jan 29, 2002 | 06:44 AM
MaximaRider's Avatar
BULLSH!T, get another opinion unless your doing nuetral drops(if ur auto) or burnouts/powershifting (if ur manual)
Old Jan 29, 2002 | 08:16 AM
95maxrider's Avatar
Lightly modded
how bad are neutral drops anyways? say from about 2500?
Old Jan 29, 2002 | 08:27 AM
iwannabmw's Avatar
Probably about the worse thing you can do to a tranny besides running it with little or no fluid. Very bad.
Old Jan 29, 2002 | 09:47 AM
Viscous's Avatar
Neutral Drop
Being stupid as I was, I thought I could do a neutral drop in a auto tranny as if it was a manual tranny. I did one neutral drop from 6500rpm that left two even tire strip marks for about 50 feet from a parking space that I was in, and smoked up the place. Not to mention it must have annoyed all 50 heads of people around me that turned to look. I feel stupid writing about it now, my tranny is still alive. Will probably be needing a new one soon
Sometimes when I add a bit of gas at around 25mph, when the car is automatically shifting from 1st to 2nd, the shifting is.. hmm how to describe it.. less than crisp. It feels like its slipping and does not fully shift into gear for about a whole second. In the mean time the car shudders slightly and the makes a rubbing noise from underneath. This only happens when I add throttle right before the car shifts... Anyone else had this problem or situation? I am curious to know.
Well, its about time for a new tranny and Don's VB mod.
Old Jan 29, 2002 | 10:03 AM
95maxrider's Avatar
Lightly modded
Re: Neutral Drop
Are all your tranny problems related to the one neutral drop you did, cause my car needs some boost right off the line, and if I drop from 3000, how bad would that be? i already have 80000 on my auto....
Old Jan 29, 2002 | 10:17 AM
Viscous's Avatar
Re: Re: Neutral Drop
One neutral drop will not damage the vehicle enough so that you can notice it immediately, but it is cumulative, meaning the more often you do it, the sooner your tranny will fall apart. So in terms of longevity, just stay away from anything stupid like that. I never knew it before, and now I know. Don't be dumb like me!
Old Jan 29, 2002 | 10:30 AM
95maxrider's Avatar
Lightly modded
Re: Re: Re: Neutral Drop
so how can i get a good launch? thats whats killing me in races
Old Jan 29, 2002 | 10:34 AM
Viscous's Avatar
Re: Re: Re: Re: Neutral Drop
Brake torquing. Hold down the brake and apply gas to about 2500 rpm and let go of the brake and apply WOT as soon as you have the go. Its definitely not as effective, but it won't kill your car before its time.
Old Jan 29, 2002 | 10:44 AM
Justin95SE's Avatar
yah i wont take my car to a place that asks me if its a 4 cylinder or a V6.
Old Jan 29, 2002 | 06:41 PM
iwannabmw's Avatar
Trade it for a 5 speed
Old Jan 29, 2002 | 06:57 PM
deezo's Avatar
Re: Re: Re: Re: Re: Neutral Drop
The shop your advertising is in Andover, do you work there??? I may have to stop up and get some lubricants for the ride.
Old Jan 30, 2002 | 01:00 PM
RapidMax's Avatar
Re: Neutral Drop
I have that same situation(I'm hoping it's not a problem) and I have 27,000 miles on my car. I notice it most when I start to accelerate and someone hits their breaks and I have to stop accelerating right away. Doesn't happen very often and I always thought(hoped) it was just the tranny being confused about which gear to go into. I've only had the car for 8k miles and I drive a little harder than average but don't abuse my tranny so I think its probably normal. Anyone else know what this is?
Old Jan 30, 2002 | 02:38 PM
meccanoble's Avatar
Sports Button FTW
how do u drive hard???
Old Jan 30, 2002 | 02:44 PM
Romping the gas almost all the time.
02PearlSE
Oct 7, 2015 02:12 AM
MaximaRaj
27
Oct 2, 2015 07:31 AM
soloist3
Sep 2, 2015 12:59 PM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
