should i replace original 275,000 coil packs?
Old Mar 23, 2016 | 09:31 PM
max ride 41's Avatar
i get sputtering in the morning, and she's running kinda rough right now. otherwise after she warms up she runs great. plugs are at 40,000 as well, so i will do them together. anything else i'm missing?
Old Mar 23, 2016 | 11:50 PM
Check plugs as the first culprit. If bad, replace with NGK plats or coppers.
If good, do the unplug a coilpack one at a time trick and listen for a change in RPM. If no change, then you've narrowed down the cylinder and coilpack/injector.
Swap coilpack with another cylinder. Repeat test and see if the no change in RPM moves with the coilpack. If so, that's your coilpack to replace. If not, then it could be the injector failing on the original cylinder.
Old Mar 24, 2016 | 12:48 AM
asand1's Avatar
No, unless they are new OEM. Parts store replacements are worse than high mileage wrecking yard coils. I have 322K on my originals.
Old Mar 24, 2016 | 05:20 AM
sweet, good to hear that. Wizard, i've done that before and i know that's the way to go, just wasn't sure at my mileage if i should replace or not. i'm doing the plugs today, throttle body cleanout, etc. went to my body shop yesterday to get an estimate for more rust that's breaking through the rear passenger side quarter and on the back rail as well, 500.00 and my guy's going to do all the rust and repaint rear door, rear quarter, rail, blend into roof. woot!!!
Old Mar 24, 2016 | 04:36 PM
so, i pulled the plugs after checking codes ( had a random misfire code ) and the rear middle was shot, cracked, and i'm wondering what caused it? maybe the last time plugs were done my tech at the time over-tightened that plug?? put all new ngk double plats in, drove her down the road and she was cruisin"!! not super fast, but for 274,000 i was happy. no more sputtering on start-up and i'm sure gas mileage will improve a bit if i can keep my lead foot off of the gas.
Old Mar 24, 2016 | 04:43 PM
Nice
Old Mar 25, 2016 | 06:37 PM
started the max up tonight and i'm still getting a little sputter noise, maybe my aftermarket exhaust is affecting idle? i think it always did, car got quiet and settled down after a few minutes, timing chain tensioner has made noise since i got the car at 129,000, so i guess at 275,000 i should count my blessings.
Old Mar 25, 2016 | 09:30 PM
aftermarket exhaust has nothing to do with how it idles at startup, or warm for that matter.
Old Mar 26, 2016 | 01:22 AM
i have no codes right now so whats causing the startup sputter? it's better now but still a little rough. i'll check the air filter tomorrow and listen for any hose leaks. what else?
Old Mar 26, 2016 | 06:11 PM
so, i take maxy out for a spin and the sputter is still there. not so much at start up but after going around the block a mile or so i'm at sonic and in drive getting ready to order and here comes the sputter again. i call my mechanic and he says he knows whats wrong, timing chain is stretched out?? i thought maybe it can cause rattle when the guides wear out but uneven idle?? is there any truth to this??
Old Mar 27, 2016 | 10:57 AM
hitachi coil pack part# igc0012....
i need to replace a coil pack, probably do all of them. the one that i think is bad is the rear middle. is this the right part?
http://www.ebay.com/itm/Ignition-Coi...FVAqvR&vxp=mtr
Old Mar 27, 2016 | 11:27 AM
JvG's Avatar
JvG
That is the one. Many people only replace the bad one. They can last a very long time. Many of the ones at the junkyard could be purchased cheap, and last for years.
If you replace only stuff which really does need to be replaced, you might have money available for other repairs.
Old Mar 27, 2016 | 11:29 AM
QueensMAX's Avatar
Hmm sounds like the upper intake manifold gasket is bad...when its cold the gasket is not sealing until the car warms up
Maxima 97 SE's Avatar
Yes but buy them from Amazon as there cheaper and ships much faster with 30 day return Window and it comes with a 1 year or 12,000 mile warranty. http://www.amazon.com/gp/aw/d/B004A0...yTL&ref=plSrch
Old Mar 27, 2016 | 01:07 PM
thanks guys, looking to save up and buy the 3 in the back and do them all at once. then the front ones next.
Old Mar 27, 2016 | 01:12 PM
o, and what da hell is this??
http://www.ebay.com/itm/Hitachi-IGC0...dWOc-M&vxp=mtr
Old Mar 27, 2016 | 01:15 PM
yeah, i'm leaning towards a bad coil pack and a possible air leak. maybe
evanspears
Mar 25, 2016 03:09 PM
Knotz428
Mar 13, 2016 07:44 AM
gwmac
Mar 12, 2016 06:55 AM
ZerotoSixty
29
Feb 29, 2016 05:13 AM
