Alternator question
Old Mar 28, 2016 | 02:25 PM
Ronen Festinger's Avatar
Alternator question
Hi, after my friend got ripped off by mechanics who didn't even fix the problem, I decided to replace the alternator by myself.
The problem was that the alternator was starting to charge after driving for a while and not all the times. So occasionally, the battery got emptied.
The mechanic for some reason said that someone switched between the 2 wires that goes to the regulator in the alternator so he switched them back. It doesn't seem to solve anything.
So my question is what is the meaning of each wire connected to the regulator. And what can cause this problem.
Measuring the voltage between the 2 wires gave me only 80 millivolt.
Old Mar 29, 2016 | 10:43 PM
DennisMik's Avatar
There are 3 wires on the alternator. The thick black/red stripe wire is the output of the alternator, is connects to the battery via the 120 or 140 amp fusible link.
The other 2 wires are in a plastic connector that plugs into the rear of the alternator.
The yellow/black stripe wire has 12 volts via fuse # 60 from the battery. This is to supply power to the field windings to create the electromagnetic field. It probably also powers the voltage regulator printed circuit board inside the alternator.
The white/red stripe wire is for the idiot light in the speedo cluster. Power from the battery via fuse # 13 goes to the light bulb and then to the alternator. If the alternator is working, 12 volts come from the alternator to the other side of the light bulb. With 12 volts on both sides of the light bulb, the light bulb does not light up. If the alternator is not working (i.e., not producing voltage) the 12 volts from fuse 13 travels through the light bulb, to the alternator and then to ground. The light bulb will light.
Measuring voltage between the 2 thin wires (yellow/black stripe and the white/red stripe) is not a valid thing to do. Swapping these 2 wires around on a working alternator won't cause any damage other than maybe reduced amperage output, but if the alternator was bad, you would probably blow fuse # 60.
But these 2 wires are in a plastic wire harness connector. How the heck is he swapping them? And how did he determine the wires were swapped in the first place? Or was he the bozo that swapped them via brute strength and ignorance?
What you need to do is take your voltmeter and measure the voltages:
1 - battery voltage when the engine is not running. Should be between 12.3 and 12.5 volts.
2 - voltage when the engine is running at idle. Should be between 13.8 and 14.5. Anything else equals bad alternator.
3 - voltage with engine running at idle, turn on every electrical device - headlights, bright lights, hazard flasher, air conditioner with fan on high speed, rear window defroster, radio, run the windows up and down, move the seat back and forth - all at the same time. Voltage reading should be between 13.8 and 14.5 volts. Anything else equals bad alternator.
Old Mar 30, 2016 | 12:21 AM
Yes, he is ignorant and rude, he cut the wires and switched them. Maybe he traced them back ans saw they are switched? Thanks for your good explanations. So one or both of the 2 wires don't produce 12 volts needed to create the magnetic field inside the alternator? that's why it gives no output? Fuse 60 is the 7.5 amp that says alt? and where is fuse 13?
Old Mar 30, 2016 | 09:18 AM
DennisMik's Avatar
You are correct about fuse 60. Fuse 13 is in the dashboard fuse panel, lower left corner. When you are looking at the fuses, #13 is in the center column, 2nd one up. If you have the label on the inside of the cover, it is called "METER".
Only the yellow/black stripe wire is used for the magnet field. The other wire, white/red stripe, is only for the ALT light in the speedo cluster. You could leave it off and it will not affect the alternator's operation.
How or why the mechanic made the determination that the wires were switched is beyond me. Those 2 wires are in a plastic connector and require a special tool that very few people have in order to switch them. Unless you cut the wires.
If you want, those 2 wires plus the one that plugs onto the a/c compressor is a short, 12 inch wire harness (part # 24076-40U00) that costs about $40 at the dealer, a lot less at the junk yard. 1995 - 2000 Maximas and Infinities use this same harness.
If you would like a wiring diagram, here is a link to the one for the 1998 Maxima. Same diagram for all the years. See pages 29 & 30 in section EL (electrical) - http://boredmder.com/FSMs/Nissan/Maxima/1998/EL.pdf
Here is the link to the index for all the year models.
Old Mar 30, 2016 | 11:33 AM
Yes. He cut the wires themselves. Mine are white/black and white/red. I Will just make sure I get 12 volts through them to the alternator. And measure voltage of ita output.
Old Apr 1, 2016 | 10:01 AM
Now there is another problem, the car turns off immediately when i press the gas, what can it be?
Old Apr 1, 2016 | 01:35 PM
JvG's Avatar
JvG
Any codes?
Old Apr 1, 2016 | 03:22 PM
I found out it was happening due to a low fuel level. Probably the fuel pump is not so good. I filled it with 2 gallons and it drives fine.
Old Apr 1, 2016 | 03:41 PM
JvG's Avatar
JvG
So what makes you think that your fuel pump is no good? How long since you changed the fuel filter?
Old Apr 1, 2016 | 08:52 PM
I read somewhere this problem is related to a fuel pump. But you are right, I should first try a fuel filter.
Old Apr 1, 2016 | 10:24 PM
DennisMik's Avatar
If there is no gas in the tank, how can that be a fuel pump problem? 95% of all the fuel pumps that people replace are good because something they read on the internet said it was bad.
Old Apr 2, 2016 | 04:19 PM
There was gas but low level. Anyway I checked the voltage in both connectors, and they have 12 volts. What else can I do?
Old Apr 2, 2016 | 06:13 PM
JvG's Avatar
JvG
How much gad is in the tank?
Did you fix your wiring issue as reccomended?
Old Apr 2, 2016 | 06:39 PM
When I put quarter of gallon it didn't start. When I put 2 gallons it starts but still turns off ocasionally. I don't know how much was there before but the meter was on empty. I don't know if the fuel low level light works. The wiring of the alternator should be fine because I measured 12 volts in both connectors but alternator doesnt produce output. I'll try disconnect its output from the battery and check again. For now, I don't know what else to check.
Old Apr 2, 2016 | 11:10 PM
vqmaxman's Avatar
Overcharge or lowcharge that's cutting you off.
Old Apr 3, 2016 | 12:46 PM
I disconnected the alternator from the battery. Started the engine. Put twelve volts into one of the ports, i get 0.2V in the output of the alternator. I guess this new alternator is bad too. I see no other choice but doing the hard job again replacing the alternator.
Old Apr 3, 2016 | 03:45 PM
JvG's Avatar
JvG
You are still very low on gas. It won't run properly until you add more Gallons , not quarts of gas.
Old Apr 9, 2016 | 12:49 PM
Ok. I fixed it, and learned many New things.
. always ask the store to test the alternator before you buy it. Only the third was good.
. the alternator won't produce high voltage of its output is disconnected from the battery.
. make sure you got 12v to the lower pin in the connector.
. the main fusible link is screwed in with 2 volts. Don't try to pull it out.
.to reach this bolts you have to pry all the tabs of the bottom part of the box.
. a standard hydraulic jack can't lift the car high enough, so you can take out the wheel. And the bottom of the car made with a cheap metal that gets bent when you lift the car.
.use alegator clips to give 12 volts to the connector from the battery to make sure the problem is not the connector. Make sure you don't short circuit or the insulation of the wire will catch fire.
. make sure you tense the belt enough or it will squeak.
. when installing the alternator. First screw the upper bolt and then the bottom. And do it from the top at the beginning.
. Never buy a nissan!
Old Apr 9, 2016 | 01:59 PM
Maxima 97 SE's Avatar
Dont buy aftermarket alternators
Dont buy any alternators from autozone, napa, oreilly, or car quest as they are not good and cheaply built and mainly because they dont put out the right voltage. What i did was go to pick n pull and pull out a original oem nissan alternator that was in like new condition and it looked like somebody had recently changed it with a new oem nissan alternator. Only buy original alternators as they last very long as my original one lasted until 250,000 miles. If you go original you save yourself time and the hassle of whats wrong now?
Old Apr 9, 2016 | 10:55 PM
asand1's Avatar
Most of what you stated is common sense. If you are shirting wires and catching insulation on fire you should not work on cars. Some of us here have over 300,000 miles and run great still.
Old Apr 10, 2016 | 10:22 AM
DennisMik's Avatar
As you said, you learned many things from this. And this is good. However, and I do not mean to disrespect you, but you still have a lot to learn. It takes time and experience.
You are incorrect, the standard hydraulic jack can most definitely lift the car high enough so that you can remove the wheel. The secret is to consult the owners manual or the service manual for the proper spots to place the jack.
If you do not place the jack in the proper spot, you will bend the body of the car. And do not blame Nissan. EVERY car is like this. There are specific spots that have been reinforced so the car may be jacked up. In fact, the majority of automobile manufacturers use the same spots. So when you learn to identify the jacking points as they are called, you can safely jack up any car.
As you continue to learn more about working on cars, you will discover that this statement was made in error.
Old Apr 10, 2016 | 12:44 PM
Icemule's Avatar
If you're going to jack the car up at the pinch welds use this tool on your jack, which you can pick up at most auto parts stores. You got the job done and learned in the process, also you will find that over time you will like your car more after you put in time and sweat to keep it running, trust me on that.
http://www.autobodytoolmart.com/pinc...GD_hoCCljw_wcB
Old Apr 12, 2016 | 08:48 AM
DennisMik's Avatar
I made my own pinchweld adapter out of scrap materials. Cost: 1 hour sweat equity.
TOP
BOTTOM
Old Apr 12, 2016 | 05:33 PM
jholley's Avatar
Thanks for the lead Dennis. This weekend I'll build one with my router, scrap wood, and worn tires.
Old Apr 13, 2016 | 09:18 AM
I've jacked many cars before, and never had this issue.
If a fuse doesn't blow when there is a short circuit that cause a fire then it's a bad electric design of the car.
I have a Renault twingo 95 for 8 years and a VW beetle 01 for about a year. Both with over 170K miles.
This one is 130K miles and with much more problems.
But I will never buy VW again too.
I cannot accept any manufacturer with so many years of experience of car production making so stupid mistakes purposely or not.
The Renault is definitely the best out of the 3 i worked on. But I'll continue to change manufacturers until I found the one that is perfect.
I also had motorcycles: suzuki gn250, honda transalp 650 , and now kawaskai klr650. All of them too had quality and design flaws.
Anyway, back to the alternator. I guess I will have to change it for the third time, now it produces too high voltage, that can reach 18 volts.
Old Apr 13, 2016 | 10:39 AM
DennisMik's Avatar
A sad fact is that rebuilt alternators have a poor reliability record. And the ones autozone sells are even worse. A word of warning, don't buy a brand new alternator that is made in China.
The short circuit stuff you never explained, but when people are connecting jumper wires directly to the battery, you by-passed any fuses in the circuit. DO NOT blame the design.
I admit that the quality of Nissan has gone downhill. The sad fact is that it started after Renault bought Nissan, so blame Carlos Goshen.
Old Apr 13, 2016 | 10:52 AM
DennisMik's Avatar
I don't advise routing a groove in the 2x4. I did that to the first one I made and it broke apart under the load after a while. The problem probably was because of the depth of that groove as I did not use tire strips on that one. Since I also made a cutout on the bottom for the floor jack cup, it was too thin for the load.
On the one in the photo, I had to shim up the tire strips. The tire strips by themselves were not thick enough. The tire strips also compress under the load and you can see the marks in the wood from the pinchweld contacting the wood.
Old Apr 14, 2016 | 11:40 AM
Icemule's Avatar
That 18 volts you got, is that from YOUR multimeter or from a auto parts store device? I ask because when my multi meter's battery gets low, it will show 18 volts at the battery.
James92SE
Mar 17, 2016 04:23 PM
Max I am
Mar 9, 2016 03:12 AM
Andy29
Mar 7, 2016 12:57 PM
Lovemyi30
Mar 2, 2016 08:28 PM
Ridge43
Mar 1, 2016 10:20 PM
