[Help] *Video* Hard Start 97 Maxima
Old Apr 18, 2016 | 07:33 PM
jchronis2552's Avatar
I have had this problem for about 6 months now.
First problem - I have to step on gas to get the car to start.
Second Problem - Sometimes when the key is turned it wont start, just clicks.
*Replaced Fuel pressure regulator already with a used OEM one from ebay.
Please post any helpful information below.
Thanks!
Old Apr 18, 2016 | 08:09 PM
Second problem sounds like your starter (solenoid) is bad
Old Apr 18, 2016 | 08:18 PM
What would usually go first - Ignition switch or Starter?
Old Apr 18, 2016 | 08:23 PM
JoshG's Avatar
for the clicking issue, its for sure the starter on its way out, thats what mine did.
also not to mention, look how much fuel u had left lol.
Old Apr 18, 2016 | 08:25 PM
Alright, I will buy a new starter then. Also, it happens when take is full as well
Will a new starter also fix the problem where I have to step on the gas for the car to start?
Old Apr 18, 2016 | 10:04 PM
JoshG's Avatar
not sure if the starter will fix the step on the gas issue. Im sure thats something else.
Old Apr 19, 2016 | 12:19 AM
LJay's Avatar
Apologize ahead of time for drifting the subject away from the OP
I've been having starting issues also. It either takes a long first turn of the key or 2 turns. I have a code for the Crankshaft position sensor. I replaced it 3 times & I'm still having the issue. No codes for anything else. It's becoming a real PITA.
Old Apr 19, 2016 | 12:21 AM
LJay's Avatar
I also checked/cleaned the other Crankshaft REF sensor & the camshaft sensor. They were fine. This hard start is STARTING to pissing me off
Old Apr 19, 2016 | 06:01 AM
Icemule's Avatar
Go with ignition switch first if you're just throwing parts at it. Have you tried wiggling the key while starting the car? Try that as it's free. If that works, then it is the switch. Do you have problems with interior lights or anything else? You might have two problems like Wizard cryptically alluded too.
Kretzmech
Mar 18, 2016 03:27 PM
KingLwood
Mar 16, 2016 04:40 PM
slickblack94
Feb 29, 2016 10:33 AM
blacrob
Feb 24, 2016 08:38 AM
Dave20
Feb 11, 2016 02:01 PM
