95 Maxima hesitation/ stalling issues
Old Mar 6, 2016 | 01:41 PM
Dasmith's Avatar
Hey everyone
I have a 95 Maxima SE that's been giving me issues, the car drives fine 90% of the time but it'll hesitate when running hard on the freeway and when I pull to a stop it'll stall out. The car will fire up fine after but usually stalls when the rpms come back down.
This primarily happens at night (I'm assuming it's temperature related), and before anyone says it:
I've cleaned the throttle body, IACV, EGR tube, I've replaced the ECTS, and I've been using Lucas fuel injector cleaner in the gas.
Old Mar 6, 2016 | 02:08 PM
Turbobink's Avatar
Originally Posted by Dasmith
Hey everyone I have a 95 Maxima SE that's been giving me issues, the car drives fine 90% of the time but it'll hesitate when running hard on the freeway and when I pull to a stop it'll stall out. The car will fire up fine after but usually stalls when the rpms come back down. This primarily happens at night (I'm assuming it's temperature related), and before anyone says it: I've cleaned the throttle body, IACV, EGR tube, I've replaced the ECTS, and I've been using Lucas fuel injector cleaner in the gas.
Sounds like a TPS issue.
Perhaps a weak/aged MAF may also the culprit.
Old Mar 7, 2016 | 12:25 PM
slickblack94's Avatar
MAF seems to be the culprit a lot of the time.
Old Mar 9, 2016 | 05:57 PM
slowmanvns's Avatar
Second that maf cause.
Old Apr 7, 2016 | 02:52 PM
Dasmith's Avatar
yea i found the problem
I had the MAF tested, it was only showing about half of the airflow coming in to the engine from the intake, which was causing the engine to run lean.
Had the MAF replaced- car no longer stalls and runs great!
now i have another small issue:
the #2 injector blew, i had it replaced. i also had the maf replaced at the same time. Now I'm noticing that the idle is a little rough (much better than it used to be but still not perfect), and when i give it a lot of throttle at 2000-2600 rpm I ca feel the car hesitate, not giving power like expected. As soon as it hits 3000 rpm its fine all the way up.
Also noticing (may be unrelated):
-light ticking noise from IACV
-car jerks when shifting into first or second gear
should I make a new post for all this??
Old Apr 7, 2016 | 08:36 PM
JvG's Avatar
JvG
Have you installed new plugs yet? Might help
What is your idle speed? Jerk in might result if it is too high.
Old Apr 10, 2016 | 09:27 AM
Dasmith's Avatar
I installed plugs about 1000 miles ago, and the idle is usually 650-700 rpm
Old Apr 10, 2016 | 12:04 PM
Icemule's Avatar
I see that you cleaned the egr tube. Did you by any chance take off the intake manifold? If so, did you replace the manifold gasket? If you took off the manifold, spray some carb cleaner or water (I know, your not suppose to spray water) around the manifold where it bolts on. If the engine rpm's change that's your problem. Also did you replace the iacv gasket and is it on properly?
Old Apr 10, 2016 | 12:23 PM
Dasmith's Avatar
I took off the throttle body and iacv but not the manifold. I just ordered new throttle body and iacv gaskets a few days ago, I'll see if that helps
I'll check for any leaks after I swap gaskets
Old Apr 15, 2016 | 03:12 PM
Dasmith's Avatar
Fixed it!!!!!!!! Turned out my throttle body gasket had the consistency of a potato chip, I swapped it out and it feels like a new car lol
Thank you everyone for the help
Old Apr 15, 2016 | 03:31 PM
JvG's Avatar
JvG
Congratulations. You stuck with the project. Now you can enjoy the results of your persistence and work.
Old Apr 15, 2016 | 07:22 PM
bumpypickle's Avatar
thanks for reporting back to us! hm...I think I need to order a few gaskets after reading this lol
Old Apr 19, 2016 | 06:59 AM
Icemule's Avatar
For sure! I spent the last week replacing all gaskets and replaced all factory hose clamps with new clamps and it feels like I had an overhaul on the motor, it was that much of a difference. Car runs great now, and I THOUGHT it was running good before all of that.
Maxima 97 SE
Dec 28, 2015 09:28 AM
jerrod99_se-l
Dec 27, 2015 05:35 PM
Quantumxl
Dec 26, 2015 11:26 AM
Jime
Dec 10, 2015 02:30 PM
