Which way do the spark plug tube seals go?
Old Apr 24, 2016 | 09:49 AM
maximaxi's Avatar
Rear valve cover gasket won't go back on unless I put the seals in backwards. With the front valve cover, I could put a screwdriver around the seal to wedge it over the tube, but it's harder to do that in the back
The brand I'm using is Victor Reinz, made in Japan. One side is flat and says Made in Japan on it. The other side has an inner ring and an outer ring.
Pic attached
Old Apr 24, 2016 | 09:57 AM
Maxima 97 SE's Avatar
Good you got the original spark plug tube seal that nissan sells and you also have them installed correctly as you did in the picture.
Old Apr 24, 2016 | 01:43 PM
Turbobink's Avatar
The install you show in your photo is correct ... as has already been pointed out.
If you're having trouble getting the seal seated onto the tube when you set the VC, apply a little Vaseline to the inner orifice of the seal (around inside the hole).
It'll help the seal slip onto the tube.
Old Apr 24, 2016 | 07:29 PM
DennisMik's Avatar
The seal that is in the valve cover is backwards. When the seal is installed in the cover, it should look like the loose seal.
Frome post - https://maxima.org/forums/5th-genera...ervations.html
3rd photo down is the cover as it was removed the engine -
Old Apr 25, 2016 | 04:10 AM
Turbobink's Avatar
Originally Posted by Maxima 97 SE
... and you also have them installed correctly as you did in the picture.
Yep ... total dumb-a**es.
M. Dalrymple
May 24, 2016 10:25 AM
Dlowe90
22
Apr 25, 2016 11:26 AM
maximaxi
Apr 24, 2016 09:45 AM
maxima183
Apr 23, 2016 06:33 AM
AT978
Apr 18, 2016 06:30 AM
