mystery connector ID needed
Old Jul 5, 2016 | 08:21 AM
gallilaw's Avatar
Age has clearly diminished my skills. So when finishing a project to replace the my 1998 five-speed Maxima's clutch cylinder fluid network with a one-piece stainless hose, I ended up with one electrical connector for which I could not identify a mate.
Photo provided.
If anyone can tell me what that little beast is supposed to connect to, and where I can find it, I will be very thankful.
Old Jul 5, 2016 | 09:13 AM
Turbobink's Avatar
Where are you in the e-compartment?
Some distinguishing features are the green internal and the yellow wrap but I can't quite tell without knowing the general geographic area within which the connector resides.
Do I think I see the intake snorkel in the background?
Old Jul 7, 2016 | 12:30 PM
gallilaw's Avatar
Thanks for responding. Sorry for the delay in getting back.
Attached photo shows the location of the connector in the engine bay. It shows where the connector now is, not necessarily where it should be. I can't find an unpaired wire with a connector to match it.
Hope you can help.
Old Jul 7, 2016 | 03:10 PM
Turbobink's Avatar
Originally Posted by gallilaw
Thanks for responding. Sorry for the delay in getting back. Attached photo shows the location of the connector in the engine bay. It shows where the connector now is, not necessarily where it should be. I can't find an unpaired wire with a connector to match it. Hope you can help.
Put your hand down and feel the rear side surface of your air intake snorkel right around the general area where it curves toward your air filter box. Maybe start by running your hand along the backside of the snorkel starting at the point where it inserts into the air box.
Running your hand towards the motor along that surface do you feel the Air Charge Temp Sensor?
Is there anything plugged in?
Old Jul 9, 2016 | 06:41 AM
gallilaw's Avatar
Found the connector. It was attached to a hard point well below the snorkel; it was dark in color and pointed directly upward and in a place where it was so hard to identify even in daylight with a flashlight that I twice had to spend five minutes looking for it even after I had initially found it. Had to take off the air box system to connect the two pieces.
Still don't know what the connected system was designed to do.
Thanks for the help.
valerit1
May 19, 2016 04:13 PM
maxima297
Mar 11, 2016 06:27 AM
RussMaxManiac
Sep 6, 2000 06:13 AM
Aug 31, 2000 11:04 AM
Aug 31, 2000 10:56 AM
