Replaced alternator but now certain electronics won't work
Old Jul 30, 2016 | 06:07 AM
maxfever1987's Avatar
I have a friend's car I changed the alternator on, install went smooth I have done this at least 100 times, upon installation the brake and battery light went off from the dash but now here's the prob there's no power to the wipers,windows, Door locks or the blower Motor, and there no parking lamps, I checked every fuse and I changed out a few relays but still nothing
The car runs and drives but these electrical components have no power going to them, any ideas war this might be?
Old Jul 30, 2016 | 10:58 AM
Turbobink's Avatar
First step would be to check the under-hood fuses (passenger side e-compartment fuse box) AND the under-hood relays (drivers side relay box).
Second, check all under-dash fuses.
Report back.
Old Jul 30, 2016 | 11:06 AM
I did check them all including the ones in the engine bay by the battery the ones by the pass side relay box and the ones under the dash on the drivers side, all of them are good and I double checked this
Old Jul 31, 2016 | 12:53 PM
Ok so now I have also changed the circuit breakers on the inside of the car and still no results I have also changed the bcm and still no results
Any ideas wat else it can be?
Old Jul 31, 2016 | 02:59 PM
DennisMik's Avatar
Look at the 65 amp fusible link that is under the hood by the battery. The cover has it labeled "FL65A ACC". It is the front most thing in the box, has a clear top.
Old Aug 1, 2016 | 06:50 AM
I put one from my own maxima into there and still nothing
Old Aug 1, 2016 | 09:59 AM
DennisMik's Avatar
This is too weird. I suppose this is a dumb question, but are you certain these things worked before you changed the alternator?
That 65 amp fusible link feeds other fuses and those secondary fuses feed the cigarette lighter, power mirrors, wipers, theft system, keyfob remote and the heater blower motor. Not fed by that fusible link are the wipers, the windows, door locks, tail lights, so it was somewhat of a shot in the dark.
So scratching my hemorrhoids (or was it my head?) some more, I looked at the next higher up fusible link that feeds that 65 amp one. This is the main fusible link on the positive battery terminal, 120 or 140 amps (cali cars/fed cars). Of course it feeds other fuses as well and these fuses do cover the windows, the tail lights, the battery light in the instrument cluster. It also covers more things than you mentioned, so I don't know if they work or not. These things are radiator fans, a/c control panel, radio memory, fog lights, horn, cruise control, and a few more things that most cars aren't equipped with.
So check that main fusible link. Maybe you'll get lucky.
Old Aug 1, 2016 | 11:09 AM
Hey thanks for ur response
These r the things which don't work
Door locks windows, climate control, wipers parking lamps horn cruise control rad fans radio Battery light in the Cluster
So it actually might be this,
BTW the car runs and drives though incase that matters,
Old Aug 3, 2016 | 06:53 AM
Prob solved it was the 140 fuse but looking at it It looked almost perfect, thanks for the help everyone
Old Aug 3, 2016 | 08:15 AM
You simply looked at the fuses? I figured you tested them when you said earlier that you "checked" them in post #1.
Old Aug 3, 2016 | 08:22 AM
DennisMik's Avatar
Excellent. Glad to hear it was something simple to replace and didn't clean out the wallet. It was weird, though.
Old Aug 3, 2016 | 06:58 PM
jholley's Avatar
Congrats on getting it solved.
I did the same thing 2 years ago. Blew that 140A fuse when replacing the alternator. I learned from the experience that both cables need to be removed off the battery terminals when relacing the alternator. Not just the NEG cable!
Old Aug 6, 2016 | 11:23 AM
I didn't test this one with the tester since it was bolted in I got lazy honestly I didn't want to rip apart his fuse box for testing it, the others ones I did since they all just pull out,
MAXSE5SPD
May 12, 2016 10:01 AM
thekevinwright
Mar 15, 2016 08:51 PM
george__
Feb 23, 2016 12:05 AM
Maxima50
Feb 22, 2016 11:17 AM
hithesh
Feb 20, 2016 02:10 PM
