Air bag light problem
Old 08-14-2016, 06:48 PM
PH98I30's Avatar
My airbag light came on about a month ago. I turned it off with the drivers door reset. Today it came on again. This time the door fix hasn't worked. Will sanding/cleaning the connector contacts help?... or am I screwed? Also, I live in Cali. Will I fail the smog test for a flashing airbag light even though it has nothing to do with emissions?
Thanks All.
PH98I30 is offline
Old 08-14-2016, 07:28 PM
EseJandro's Avatar
Thanks All.
Also from cali. Thats my #1 fear when anything goes wrong. Damn you smog checks!
EseJandro is offline
Old 08-14-2016, 10:16 PM
JvG
JvG's Avatar
I often clean the connection. at least check it.
My comments on this forum apply mostly in areas which use road salt. this causes corrosion and iffy intermittent contact.
it would help to know where the car lived before you bought it.
if the car looks rusty, the electric contacts are probably corroded in exposed areas.
JvG is offline
Old 08-15-2016, 10:18 AM
PowerTotheMax's Avatar
Thanks All.
Also from Cali. Had that light since I bought the car. I just ignore it after so many times I reset it. It doesn't affect smog check.
PowerTotheMax is offline
Old 08-27-2016, 06:14 PM
PH98I30's Avatar
After trying to reset the A/B light for 10 days, I gave up on it. Today out of desperation, I pushed the connectors back together even though they did not feel lose. I tried the reset protocol out of curiosity and the light went off. I am happy as a hooker. I guess a very little lose makes a difference.
PH98I30 is offline
Old 08-27-2016, 07:13 PM
JoshG's Avatar
So wait what connectors did u push back together? I have had my airbag light on for the past 3 years, but I remember it happened right after my friend put the passenger seat all the way back and down, don't know if the connector got disconnected underneath it?
JoshG is offline
Old 08-28-2016, 02:41 PM
JvG
JvG's Avatar
Josh, cleaning your contacts where the seat connects to the harness might solve your problem. You might want to look for a broken wire as well.
Having the light come on after your friend lowered the seat is a clear clue.
JvG is offline
Old 08-28-2016, 05:55 PM
PH98I30's Avatar
My problem was my drivers side under the seat. My wife lets water bottles roll around under the seat. I don't know which plug is to the airbag, so I pushed every connector I could see together. There is one up under the seat and one by the seat forward/backward adjustment track on the floor.
PH98I30 is offline
Heel Til I Die
04-15-2016 07:55 AM
jmlee44
04-13-2016 10:11 AM
Maxima50
02-22-2016 11:17 AM
RippinUdders
02-20-2016 05:24 AM
crsmax
08-22-2000 12:43 PM
Quick Reply: Air bag light problem
