ABS Speed Sensor cable split
Old Aug 15, 2016 | 04:17 PM
surban1's Avatar
the abs light came on; code 31 indicated that the right rear abs speed sensor has an "open circuit." a visual revealed that the cable is separated; it seems to have split right where the rubber grommet thingy attaches near the caliper. is it possible to just splice the cable back together? how many wires run inside the cable? any chance of getting a good used one or does removal destroy them?
thanks in advance for any help.
Old Aug 16, 2016 | 03:27 AM
DennisMik's Avatar
Soldering the wire would be OK if you have the room to do it. If the wires are broken too close to the sensor, then it may not be possible. There are 2 wires in the cable.
Getting a junkyard replacement is OK.
Old Sep 7, 2016 | 12:30 PM
surban1's Avatar
spliced it and all is fine again. thanks dennis for the good info.
Veparisi
Mar 9, 2016 04:09 PM
ac max 92
Mar 8, 2016 05:40 PM
ericdwong
Jan 25, 2012 09:37 AM
DRN90GXE
Aug 24, 2000 09:39 AM
