Rear glass, when rains, leaking lots of water into trunk
Old Aug 26, 2016 | 07:44 PM
ottos's Avatar
After I had Safelite Glass replace the back or rear glass, now when it rains I have lots of water in the trunk. As this was under warranty, they removed and replaced the same piece of glass with a new seal and caulk all the way around the window. However, it still leaks. They said they thought it was due to the seals around the screws being old and loose. We tried it with a garden hose, to isolate the back window, so I know its not from the sunroof. I'm not sure where exactly on the back glass the water is coming in, but I think its in the lower border of the glass, the side closest to the trunk. Any suggestions on how to fix?
Old Aug 27, 2016 | 06:34 AM
max ride 41's Avatar
those idiots tooks 3 weeks to properly fix my front windshield. they put cheap plastic molding on that when i went driving down the highway, it blew off. i insisted they put the oem metal/rubber molding back on and my ins. company agreed. take it back and tell them you want it fixed the right way, or give you your money back.
Old Aug 27, 2016 | 06:45 AM
ottos's Avatar
The black lining on mine that they put all around the window, appears to be rubber. I dont know if its high or low quality.
Old Aug 27, 2016 | 02:12 PM
more than likely, it's some cheap aftermarket molding they used. put up a pic or 2 of the molding and trunk area where it's leaking, i guarantee it's not oem molding and they should fix and put proper molding ( oem ) back on.
hybrid775
32
Jul 4, 2016 09:26 AM
tomtek
Apr 22, 2016 10:20 AM
ColdCananda
Apr 15, 2016 01:13 AM
googus
Feb 17, 2016 04:16 AM
ColdCananda
Feb 16, 2016 03:50 PM
