Replacing low beams with led on 2016 SL
Old Mar 12, 2016 | 02:23 AM
tomtek's Avatar
How do you go about replacing the low beams with leds on a 2016 SL. Is there a video available or a step by step procedure. I do not want to remove the bumper.
Old Mar 12, 2016 | 08:18 AM
Take off the wheel, the wheel well liner clips, and then you should have access to the headlights.
Old Mar 14, 2016 | 02:33 AM
mannino89's Avatar
I didn't take my wheel well off. Just turn the steering wheel all the way to the right to change the left headlight, etc. there's 3 push clips I popped out & then just pushed the liner to the side & had access to the headlight bulb. I used the opt7 flux beams & had to install the polarity adapters that came w it. It's just an extra wire, nothing major.
Old Mar 14, 2016 | 10:34 AM
Walkingtree87's Avatar
Same here. I changed out my lights yesterday. All I did was turn the wheel and remove the wheel well clips. Took 10 mins total.
Old Apr 22, 2016 | 10:03 AM
central25thst's Avatar
has anyone tried these hids?
Amazon.com: Innovited AC 55W HID Xenon Conversion Kit With "Slim" ballast - H3 - 3000K - 2 Bulbs & 2 Ballasts: Automotive Amazon.com: Innovited AC 55W HID Xenon Conversion Kit With "Slim" ballast - H3 - 3000K - 2 Bulbs & 2 Ballasts: Automotive
Im looking at the h11 but just curious on any feed back for these?
Old Apr 22, 2016 | 10:08 AM
With HID's, you get what you pay for. Go for a good set. I haven't personally tried these, but I would recommend going with the Morimotos. Also, you linked an H3 bulb, make sure to get the H11. And 3K is yellow, go for either 5k or 6k.
Old Apr 22, 2016 | 10:20 AM
https://www.theretrofitsource.com/hi...l#.Vxpa63qHnzc
maximafan2016
Dec 7, 2020 06:31 PM
mikel-
Mar 14, 2016 03:12 PM
Soxy
Mar 9, 2016 10:00 PM
tarun900
Mar 9, 2016 05:09 AM
ac max 92
Mar 8, 2016 05:40 PM
