HID light problems
HID light problems
Forum noob..Long time lurker
Just took these HID's off my 95 max
I try and put em in in my 97 and these are the results I get when on regular lights and hi beams
Help
AC Ballast btw
Help
AC Ballast btw
Could you kindly explain what is going on? You don't provide enough information in the post. I can see a yellow-ish on the driver side in first pic, then brighter in the 2nd pic. I'm assuming the 2nd pic is highs.
What's the question?
Pretty much how do I get both of the lights to be all one color? When I switch the high beams on they're supposed to be all blue and when they're not on the original yellowish color. I tried changing sides but got the same results. I'm not sure what's going on.
patience my friend, as reality check has stated : The problem is that one pin in both plug sockets are switched. You have to carefully push out one of the pins and swap in a different spot of another pin. take your time and watch what your doing and make sure it's hooked up properly. gl
dealsgap
Apr 15, 2016 03:54 PM
Roblee
Mar 18, 2016 02:26 PM
