Starting issue, HELP!
Old Apr 23, 2017 | 09:01 AM
Snabors's Avatar
Hello guys,
I'm here seeking help on the starting issue on my 4th Gen 98' maxima.
My ignition switch was bad. I bought a new one and during reinstall, the screwdriver tapped the wire on the back. There was a spark and pop and now I can't start the car. No crank, no start.
I was able to start from the actual starter under the hood. I bought another switch. How do I figure out what exactly is the culprit at this point.
HELPPPPP!
Old Apr 23, 2017 | 11:57 AM
Start checking all fuses....
I can never understand why people do electrical work with the battery still hooked up.
Shoot, whether I do mechanical work or electrical work, I always disconnect both terminals at the battery.
Old Apr 24, 2017 | 07:56 AM
Snabors's Avatar
I've replaced blown fuses
Old Apr 24, 2017 | 08:54 PM
DennisMik's Avatar
OK, great. Did this solve your problem?
Old Apr 25, 2017 | 08:35 AM
Snabors's Avatar
No, I think it's a wire but not sure how to diagnose
Old Apr 25, 2017 | 08:41 AM
What makes you think it's a wire? Whatever wire you think is bad, check it for continuity. Jump on Youtube and search for "How to check continuity". It's very simply.
It still could be a fuse, fuseable link, relay etc
Old Apr 25, 2017 | 08:42 AM
Snabors's Avatar
Ok, I'll update
Old Apr 26, 2017 | 09:33 PM
DennisMik's Avatar
Did you check the fuses under the hood? there is a 30 amp fuse that sends power to the ignition switch and then on to the starter. These fuses are by the battery, next tot the fender. Check fuse H, a green square fuse that the cover calls IGN SW.
