Y Pipe Exhaust Leak
Old Apr 26, 2017 | 01:12 PM
Violator's Avatar
Y Pipe Exhaust Leak
Long story short I have the cheap eBay's y pipe/headers (regret) I've already dumped money and time into moving the O2 sensor.
2 of the 3 studs broke that are bolts welded into the front header for the y pipe to tighten up with nuts. Muffler shop wants me to remove headers so they can put new studs in said they didn't have enough room. I really don't want to remove those headers again I just did coolant and i think the stock nuts for the headers were starting to strip
There's a healthy gap and exhaust leak between flanges with only one of three corners tightened, down how do I fix without removing header? This guy probably didn't even move the compressor, would there be enough space even between the engine block to weld?
Old Apr 26, 2017 | 03:19 PM
krismax's Avatar
Father of the 00 VI
those studs should be screwed in not welded. And cast iron doesn't weld very well. And wither you did the y-pipe or not, stock ones always rot off.
those studs always go bad also. No body should be welding ,they should be putting new studs in.
Old Apr 26, 2017 | 03:48 PM
Violator's Avatar
They are eBay aftermarkets the manzo header/y pipe set. They are bolts welded onto the header like studs
Old Apr 27, 2017 | 10:18 PM
krismax's Avatar
Father of the 00 VI
can they drill the studs out and put nuts and bolts in? or drill it out tap it and use bolts?
the ones i bought, are like that. They just threaded holes so a bolt can just be used.
Check this thread out second page shows the shorty headers bought they are 4 th gen headers.
https://maxima.org/forums/5th-genera...lean-up-2.html
Old Apr 28, 2017 | 06:00 AM
Violator's Avatar
Exactly like those except my studs are bolts welded in
