alt battery light help.
Old Jul 12, 2017 | 04:49 PM
maximaham's Avatar
hi all when alt went out so i replaced it. Now i get a flickering battery light but some times it stays on. Battery is barely a year old. When the battery light comes on the brake light also comes on.
I have checked all the fuses and fuse links.
I have the battery on a slow charge for now.
Has anyone had any first hand experience with this problem.
Old Jul 12, 2017 | 07:16 PM
DennisMik's Avatar
Yes, we have lots of experience with rebuilt alternators.
You have a bad one. Take it back and get it replaced.
Sad but true.
Old Jul 12, 2017 | 10:37 PM
maximaham's Avatar
Now i have to get in touch with Amazon. To see what the guy will do.
Old Jul 13, 2017 | 05:10 AM
Turbobink's Avatar
Sad but true.
Agreed ...
Alternator Trouble Lamp + Battery Trouble Lamp = Failed/failing alternator (typically).
Don't suppose you've done any diagnostics on the alternator?
Old Jul 13, 2017 | 05:12 AM
Turbobink's Avatar
I realize the attraction of remanufactured parts and I've purchased my share.
However, if this is an option you chose, I'd recommend purchasing units that include a LLT warranty and purchase them from a local parts store.
Old Jul 13, 2017 | 08:31 AM
DennisMik's Avatar
I agree - I always get alternators and starters from a local store - just in case...
Old Jul 13, 2017 | 10:59 AM
reallywildstuff's Avatar
https://maxima.org/forums/4th-genera...new-one-2.html
AutoZone DLG13284 is what I'm running now, no problems (at least not like the Bravo MF Sierra problems described in that thread omg)
Old Jul 13, 2017 | 11:18 AM
maximaham's Avatar
i guess it a gamble wit alts thees days. 1 sec its charging @ 11.9 volts next sec it @ 15.2 wtf.
Old Jul 13, 2017 | 11:54 AM
Turbobink's Avatar
You might also consider that your charge cable and/or your ground may be failed/failing.
A voltage drop test might be in order as well.
Old Jul 13, 2017 | 12:42 PM
maximaham's Avatar
i have up graded those, i've done the big 3
Old Jul 13, 2017 | 01:01 PM
KP11520's Avatar
Hey Ham!
How you been? I hope all is well!
Alternators top voltage output is never to exceed 14.2 volts, so that alternator definitely has a problem, and will only get worse. Maybe even stress the battery.
Nothin like some good fried battery with hot sauce! LOL Better than a Philly Cheesesteak.
Good luck with the swap and let's hope they give you one that's right and won't go sideways prematurely!
