Check Engine Light
Old 08-30-2017, 05:51 PM
slowmanvns's Avatar
Check Engine Light
Doesn't this light come on temporarily whenever the car is started just to ensure the bulb is working? For some reason mine isn't anymore. I' can get it to blink the error codes by using the ecu screw. What could be the reason?
slowmanvns is offline
Old 08-30-2017, 06:15 PM
max ride 41's Avatar
what year maxima? those bulbs can burn out, or ( hopefully not ) the ecu isn't working properly. you have a scanner? run to see if you have any codes pending, if it doesn't read the ecu, you might have a problem.
max ride 41 is offline
Old 08-30-2017, 06:41 PM
slowmanvns's Avatar
Yes I have a cheap scanner. It's a 96 SE Maxima. In don't think it has burnt out because it was lit just a few minutes earlier but who know what can happen within then.
Old 08-31-2017, 09:49 AM
What does that mean?
DizzyEdge's Avatar
Well, I mean any bulb that burns out will be lit moments before it burns out.
DizzyEdge is offline
Old 12-08-2017, 01:37 PM
Tiki Oz's Avatar
I have no Check Engine Light or overdrive light .
I am thinking it a wiring harness some where.
Tiki Oz is offline
Old 12-08-2017, 01:43 PM
Turbobink's Avatar
If your MIL bulb is burnt or failing, you're ECU will store a code ... P0650.
But you'll need a scan tool to see the code.
Turbobink is offline
Old 12-09-2017, 04:39 AM
Tiki Oz's Avatar
went to autozone
I have P0110 P0325 P0600 P1605 P0138 P0600 P1605
Tiki Oz is offline
Old 12-09-2017, 01:49 PM
DennisMik's Avatar
See your post in the "I am new here section".
DennisMik is offline
