scary orange service light is ON $#$%
Old Feb 1, 2002 | 11:50 PM
k-man's Avatar
my max has been steadily dripping oil and i've had the pan's seal checked and the oil pressure sending unit replaced- still...but for the last week it has grown from a quarter sized spot to about a fist and on the highway tonight the nasty orange service engine light came on as I was driving and stayed on. Gonna look at it in the morning, but does anybody have a clue or previous experience what the f--- is going on?
Old Feb 2, 2002 | 12:49 AM
KWheelzSB's Avatar
Re: scary orange service light is ON $#$%
Depending on your model year, you may be able to pull the codes from the ECU yourself to get an idea what the problem is. It may be totally unrelated to the oil leak.
Do a search for "ECU" or "ECU codes" or "ECU reset"
You should also try to isolate the source of the leak - get your car on ramps or jackstands & slide under to have a look.
Old Feb 2, 2002 | 05:10 AM
redmaxpa007's Avatar
i SeE what you did therE
Re: Re: scary orange service light is ON $#$%
www.maximadriver.com has the diagnostic/reset of the ecu in the how-2 section...
i agree.. get under there and check it out!
Old Feb 2, 2002 | 08:15 AM
clee130's Avatar
Why would you need to do a search?
Isn't there a sticky up top called "ECU Diagnostic (Check Engine Light) Trouble Codes"?
Yep! There is!
Old Feb 2, 2002 | 05:10 PM
KWheelzSB's Avatar
Re: Re: Re: scary orange service light is ON $#$%
Yep! There is!
Search for the sticky, search the entire .org. . .
-you're splitting hairs, don't you think?
"search" (wherever) as a first effort, as opposed to "asking" the widely covered question - was the jist of it.
I'm on your side here, cheeky-clee!
Old Feb 7, 2002 | 11:41 AM
dashingMax's Avatar
THE STICKY IS GONE!!!
Old Feb 7, 2002 | 11:46 AM
loose hose ? cracked clamp..
Old Feb 7, 2002 | 02:06 PM
SuDZ's Avatar
Can you see under the car where the leak is originating from? I mean so you could tell if it was not coming from on spot in particular other than the pan. Just trying to think of a way to pin point it to one location.
SuDZ
Old Feb 7, 2002 | 04:36 PM
k-man's Avatar
well- the code came back transmission...but mech said code did NOT isolate the problem to the transmission or the electrical system in charge of the tranny- SO, I am guessing that the leak I had might be from the transmission...but my max would NOT start after the engine light incident...trade it in? transmission place will tell me tomorrow whether or not it is the tran or the electrics? any priors with this???
Old Feb 7, 2002 | 07:34 PM
whoa tranny already...??? whas the mileage on the car bro ?
i was drippin oil be4 and it was my tranny seal ...n it got replaced..and i neva had a problem since ...
Old Feb 7, 2002 | 09:40 PM
SoccrZ's Avatar
Redmaxpa007, I've seen several of your posts and after viewing your sig many times, I've got you say that your Max is hands down abosolutely badass. The color and the rims/tires looks sweet. Props to you.
Old Feb 7, 2002 | 10:42 PM
k-man's Avatar
just rolled 77000 the day it quit
minsbang
Sep 11, 2015 08:48 PM
Maxima30
Sep 7, 2015 06:13 PM
jfl330
Sep 4, 2015 01:44 PM
