Brake pedal won't fully return, causes drag.
Old Mar 5, 2018 | 06:39 PM
BFox's Avatar
Once my 97 GXE warms up a bit, the brakes start to drag. I think it's only the front right, but the front left will get hot too. After just a few miles, the car is not drivable. Once it cools down, they work fine for a few miles and then the process start over.
So far I have replaced the calipers, rotors and pads. I also got a master cylinder from a junk yard and replaced that. Bled the master. Bled all wheels but the problem persists.
When I was about to call it a night, my friend told me to pull the brake pedal back with my foot. Low and behold, it moves freely! The drag is gone...until I let off the back pressure I'd applied.
So...does anyone know what is going on? I have one friend saying it's the brake booster, and one saying it's the push rod that inserts into the master from the booster. I am stumped. Thank you.
Old Mar 5, 2018 | 07:05 PM
JvG's Avatar
JvG
The rubber brake hoses deteriorate from the inside out. The rubber starts to delaminate and peel.
That in turn basicly creates a one-way valve.
The rubber "valve" will allow brake fluid to pass while under pressure, but not when you take your foot off the brake. So the caliper will remain under some pressure.
The brake pads will drag on the rotor. That creates heat and will also cause the pad and rotor to wear.
It's possible that one side will stick, while the other side will operate normally. That will cause the car to want to turn right or left when you hit the brakes hard.
Replace both hoses.
Old Mar 6, 2018 | 05:59 PM
Rit's Avatar
Rit
Yep - what he said !
Old Mar 6, 2018 | 09:14 PM
CMax03's Avatar
Upgrade to Goodridge SS lines....
Old Mar 7, 2018 | 10:14 AM
DennisMik's Avatar
Another possibility are the slider pins on the caliper assembly.
Old Mar 7, 2018 | 11:35 AM
JvG's Avatar
JvG
Agreed.
2_da_max101
Oct 26, 2012 09:17 AM
Deckdout2
Jun 6, 2011 05:57 AM
CapedCadaver
Jul 23, 2008 10:59 AM
farscaper
18
Oct 19, 2007 08:17 AM
