Maxima 95 I drive the car, the engine shuts down every 10 miles.
Old Mar 22, 2018 | 09:38 PM
emilianonp's Avatar
Maxima 95 help please
I'm sorry, my English is not good
plus 6 months with problems nissan maxima 95 ..
I changed all the parts, including the computer
the car walks 10 minutes stops.
After 20 minutes, he starts working 20 minutes and the problem returns
I lost more than 300 dollars in exchange for pieces and this is the same
Do you have any help?
please, I thank you
Old Mar 22, 2018 | 10:42 PM
max ride 41's Avatar
please, I thank you
are your lights dimming after you start it or while your trying to start it? i would guess maybe a bad alternator. any codes? get an obd-2 reader and scan for codes, that'll help narrow it down a bit.
Old Mar 23, 2018 | 06:55 AM
CS_AR's Avatar
I have a riding lawnmower that would run for 10 minutes then quit like it was out of gas. Then if I let it sit for about 20 minutes it will start up and run again. It turned out to be the gas cap has an air valve that needs to be open or the gas tank will develop a vacuum.
When your car stops running, try opening the gas cap to see if something like that could be going on.
Old Mar 23, 2018 | 09:08 AM
JvG's Avatar
JvG
It takes about ten minutes for the engine to come up to running temperature.
I'm thinking that the engine control temperature thermostat has bad connection, or is defective.
Old Mar 23, 2018 | 10:58 AM
^known as the ECTS (Engine Coolant Temp Sensor). Simple to diagnose, test, replace if necessary.
GunTOOT
25
Apr 8, 2012 09:39 AM
viktornguyen
Fluids and Lubricants
22
Dec 9, 2004 03:54 PM
WOODYMAX98
Mar 29, 2003 04:51 PM
redzero
Mar 27, 2003 11:11 PM
CKNY
Apr 29, 2001 09:40 AM
