Question Stumped
Question Stumped stalling
My 98 has been shutting off while driving. i ran codes replaced o2 sensor it called for also knock sensor maf sensor isnt bad. had a misfire so replaced the plugs and coils, that went away. felt good after all that then it all came back the next day codes rough idle exhaust drumming. it shut off again started after a few minutes bogged out a little until i got it up to 60 and set cruise control. im totally stumped.
its weird i just took it out after it sitting for a few hours and drove it about 18 miles and it stalled alot then i set cruise control at 60 and didnt bog out or idle rough or stall, it doesnt do it when its cold and doesnt do it all the time when warm, it starts right back up and sometimes i floor it and it wont idle funny at all then goes down stall a few times and then drives fine after playing with it for a few times, kind of thinking fuel injectors? i replaced the coils one was so used it broke at the neck when i pulled it up
that makes sense but did it cause a foul odor like exhaust at all? cuz everytime it would shut off i noticed a smelly that was bad
Why?????
The Engine Control Temperature Sensor, or ECTS,
tells the ecu how warm the engine is. The computer cause a richer mixture when the engine is cold, and leaner when it is warm.
One common failure symptom is an engine which runs fine when it is cold, but cuts out or runs rough when warm. Sound familiar?
Its not expensive.
Its not expensive.
busterdawg22
04-04-2006 05:08 PM
SiCkBLaCKMaX99
19
07-21-2005 02:05 PM
NISMO808
04-08-2001 08:24 PM
