Work around on EGR valve
Any one know of a workaround to eliminate the EGR valve to save the agony of having to to decoke the thing?Live In Ia.and no smog inspections.
Save yourself a headache and just pick up a new tube.
Nissan part number 14725-40U02
A gallon of carb cleaner runs between $30 to $35. I've soaked the tube and other components for a few days to get them completely cleaned up. I think its a toss up on time vs. cost.
95 ecu i changed my 96 to a 95 .no cel
No only does it turn off the cel. it removes all EGR components,just buy a plug for $5.00 . Also those egr pipes not only clog the tubes up they fill the Intake manifold with soot
I've soaked the tube in carb cleaner overnight.
I made a container out of aluminum foil just large enough to place the tube into. It will require only one pint or quart of carb cleaner.
Then I started poking various tool's it the passage like screwdrivers, steel and copper cable, etc.
This process takes some time, but saves the 50 dollars.
be sure to clean out the passage under the egr.
240sx block off plate modified to fit the UIM (will need longer bolts), remove EGR temp sensor from tube, remove tube from rear exhaust manifold, plug rear exhaust manifold with 6th gen block off plug, leave EGRC solenoid hooked up, leave EGR temp sensor tangling near the block/rear exhaust manifold.
Also, get aquainted with the SEARCH feature on this forum. This proceedure has been covered before, with good photos
